> Help me find my oil leak!
bkrantz
post Jan 5 2023, 09:24 PM
As I described in my build thread, last year, once I got the engine running, I noticed significant oil drops (or more) after each drive. With winter in full throttle, I decided to drop the motor, and see about fixing the leak.
Here's the view of the front. Maybe you can see some oil.
bkrantz
post Jan 6 2023, 09:54 PM
Thanks everyone. Based on what I see so far, I will replace the front shaft seal and O-ring, after checking the seal surface on the hub, reseal the oil pump cover, and replace the oil filter. Any other ideas?
bkrantz   Help me find my oil leak!   Jan 5 2023, 09:24 PM
bkrantz   I found some oil inside the inner blowing housing,...   Jan 5 2023, 09:26 PM
bkrantz   Starting from the top, the case seam looks OK.   Jan 5 2023, 09:27 PM
Krieger   Starting from the top, the case seam looks OK. ...   Jan 7 2023, 08:29 PM
bkrantz   The front seal looks a bit oil wet. But is the se...   Jan 5 2023, 09:29 PM
bkrantz   Lots of oil sitting on the top edge of the oil pum...   Jan 5 2023, 09:30 PM
bkrantz   Quite a bit of oil pooled in the right motor mount...   Jan 5 2023, 09:31 PM
bkrantz   No oil visible where I would expect it if the cool...   Jan 5 2023, 09:33 PM
bkrantz   Some oil sitting on top of the filter.   Jan 5 2023, 09:34 PM
bkrantz   Meanwhile, underneath I might have just a bit of o...   Jan 5 2023, 09:36 PM
bkrantz   But the inner seals, and the cylinder-to-case join...   Jan 5 2023, 09:38 PM
Shivers   Looking at that black wire on the front of the eng...   Jan 6 2023, 08:00 AM
porschetub   Looking at that black wire on the front of the en...   Jan 6 2023, 01:35 PM
dr914@autoatlanta.com   you have an aftermarket oil pump, they are very ve...   Jan 6 2023, 01:36 PM
930cabman   you have an aftermarket oil pump, they are very v...   Jan 6 2023, 02:20 PM
Superhawk996   [quote name='dr914@autoatlanta.com' post='3049581...   Jan 6 2023, 09:58 PM
930cabman   [quote name='dr914@autoatlanta.com' post='304958...   Jan 7 2023, 06:38 AM
Superhawk996   I have wondered the same. Is this an application...   Jan 7 2023, 09:44 AM
930cabman   I have wondered the same. Is this an applicatio...   Jan 7 2023, 06:19 PM
bkrantz   I have wondered the same. Is this an applicatio...   Jan 7 2023, 09:16 PM
Superhawk996   [quote name='Superhawk996' post='3049751' date='J...   Jan 7 2023, 11:23 PM
bkrantz   Thanks everyone. Based on what I see so far, I wi...   Jan 6 2023, 09:54 PM
Superhawk996   I think you have oil going in the direction of the...   Jan 7 2023, 11:50 PM
cassmcentee   Is it possible to have a Wobble in the Crankshaft?...   Jan 8 2023, 04:35 AM
Shivers   Is it possible to have a Wobble in the Crankshaft...   Jan 8 2023, 07:08 AM
BeatNavy   My two cents from my experience here: http://www.9...   Jan 8 2023, 08:06 AM
Geezer914   If your oil pump cover was leaking, oil would be d...   Jan 8 2023, 04:56 PM
bkrantz   More thanks, everyone. During assembly, I used a ...   Jan 8 2023, 10:13 PM
searunner   As I described in my build thread, last year, onc...   Jan 9 2023, 04:32 AM
bkrantz   OK, more info. And in my quest for the right answ...   Jan 9 2023, 08:12 PM
bkrantz   I confirmed this by running a Qtip around the base...   Jan 9 2023, 08:15 PM
bkrantz   First stupid: when I went to unscrew the oil filte...   Jan 9 2023, 08:21 PM
bkrantz   No obvious leak point around the pump cover.   Jan 9 2023, 08:22 PM
bkrantz   No leaks around the studs.   Jan 9 2023, 08:23 PM
bkrantz   Here's the cover off. No dramatic scoring. A...   Jan 9 2023, 08:25 PM
930cabman   Here's the cover off. No dramatic scoring. ...   Jan 10 2023, 12:26 PM
bkrantz   Here's the cover off. No dramatic scoring. ...   Jan 10 2023, 07:46 PM
bkrantz   And the pump itself. BTW, if I need to pull this,...   Jan 9 2023, 08:26 PM
iankarr   I have the same oil pump cover and it was farrrr f...   Jan 9 2023, 08:50 PM
cassmcentee   Great news! Nothing crazy   Jan 9 2023, 09:15 PM
bkrantz   Great news! Nothing crazy But perhaps prett...   Jan 10 2023, 07:37 PM
r_towle   Is there a slot in the body and cover for an o-rin...   Jan 10 2023, 07:54 PM
bkrantz   Is there a slot in the body and cover for an o-ri...   Jan 11 2023, 08:22 PM
nathanxnathan   The fan tends to suck in and redistribute oil all ...   Jan 11 2023, 11:44 PM
bkrantz   Thanks, everyone. Going back to my build thread.   Jan 14 2023, 09:26 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:20 PM
