pistonboy |
Newbie ![]() Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None ![]() |
Hello
In the past, I removed rear camber shims from my car. Since then, trailing arm bushings have been replaced and I need to return the shim stack to its original thickness. I usually keep a record of such changes, but apparently I failed to record it or keep the old shims. I believe all shims were the same thickness. Can anyone measure the thickness of a spare shim they have? Also, how many shims are installed at each wheel? I suspect all vehicles had the same number of shims, though not guaranteed. I have replacement shims from 914 Rubber which are of varying thickness, but I believe the original shims were all the same thickness. Thank you. Sincerely, Shimless Jim |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
First find a good shop that can do a 4 wheel alignment
They are getting hard to find Then take shims to the shop |
Lo-Fi Version | Time is now: 10th June 2024 - 08:40 AM |
