pistonboy |
Newbie ![]() Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None ![]() |
Hello
In the past, I removed rear camber shims from my car. Since then, trailing arm bushings have been replaced and I need to return the shim stack to its original thickness. I usually keep a record of such changes, but apparently I failed to record it or keep the old shims. I believe all shims were the same thickness. Can anyone measure the thickness of a spare shim they have? Also, how many shims are installed at each wheel? I suspect all vehicles had the same number of shims, though not guaranteed. I have replacement shims from 914 Rubber which are of varying thickness, but I believe the original shims were all the same thickness. Thank you. Sincerely, Shimless Jim |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
@StarBear you gotta link for where to buy those things?
StarBear |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,911 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
If you mean the plugs, I think both AA and 914Rubber sell them and maybe Pelican, too. They are similar to original but without the markings. If the shims, I think I got the kit with bolts from 914Rubber. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:50 PM |
