Rear camber shims, Rear camber shims number and thickness |
pistonboy |
Jan 9 2023, 12:14 AM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
In the past, I removed rear camber shims from my car. Since then, trailing arm bushings have been replaced and I need to return the shim stack to its original thickness. I usually keep a record of such changes, but apparently I failed to record it or keep the old shims. I believe all shims were the same thickness. Can anyone measure the thickness of a spare shim they have? Also, how many shims are installed at each wheel? I suspect all vehicles had the same number of shims, though not guaranteed. I have replacement shims from 914 Rubber which are of varying thickness, but I believe the original shims were all the same thickness. Thank you. Sincerely, Shimless Jim |
jc73-914 |
Jan 9 2023, 12:16 PM
Newbie Group: Members Posts: 30 Joined: 28-May 15 From: Richmond, B.C. Canada Member No.: 18,769 Region Association: Canada |
Just curious if any member has done the rear alignment at home.
SirAndy |
Jan 9 2023, 12:41 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just curious if any member has done the rear alignment at home. Yes, i have. You're going to need a string setup, like the Smart Racing setup below for example. https://www.smartracingproducts.com/smartstrings It's a pretty tedious process, but it can be done on any level surface. (IMG:style_emoticons/default/smile.gif) PS: For best results, you also want a way to corner balance the car before doing the alignment. |
brant |
Jan 9 2023, 12:49 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Just curious if any member has done the rear alignment at home. Yes, i have. You're going to need a string setup, like the Smart Racing setup below for example. https://www.smartracingproducts.com/smartstrings It's a pretty tedious process, but it can be done on any level surface. (IMG:style_emoticons/default/smile.gif) PS: For best results, you also want a way to corner balance the car before doing the alignment. and ride height before Corner balance... |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:43 AM |
