| mb911 |
Jan 11 2023, 08:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| ClayPerrine |
Jan 12 2023, 08:51 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Why not use these?
![]() https://store.jenvey.co.uk/heritage/heritag...ottle-body-42mm They are a bolt on replacement for Weber IDA3C carbs. All of the EFI stuff is inside the throttle bodies. |
| Superhawk996 |
Jan 12 2023, 09:17 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,733 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Why not use these? ![]() https://store.jenvey.co.uk/heritage/heritag...ottle-body-42mm They are a bolt on replacement for Weber IDA3C carbs. All of the EFI stuff is inside the throttle bodies. Pretty cool - but come on $3800? (IMG:style_emoticons/default/huh.gif) The thing I don’t get with the Jenvey’s Is where the injectors are spraying to? The angle of the injectors seems to be that they spray into a passage like a carb jet instead of directly into the air stream? Maybe I’m just not seeing it correctly but Google doesn’t seem to reveal details of their fuel flow path? The potential to use a common set of carbs as throttle bodies and to repurpose the MFI / CIS ports on some of the early engines is what makes this proposal that Ben is showing unique vs a set of PMO ITB’s, Jenvey’s, or any number of other high(er) cost EFI solutions were you have to ditch the carbs and buy all new ITB’s (IMG:style_emoticons/default/drooley.gif) |
mb911 EFI project has started Jan 11 2023, 08:11 PM
Superhawk996 You’re being a tease
What ECU?
Planning to ru... Jan 12 2023, 12:09 AM
mb911 Phil,
Gonna use mega squirt. I have base map’s ... Jan 12 2023, 05:17 AM
JamesM
Phil,
Gonna use mega squirt. I have base map’s... Jan 12 2023, 11:00 AM
bbrock :popcorn: Will be watching closely. I'm still... Jan 12 2023, 08:38 AM
ClayPerrine
[quote name='ClayPerrine' post='3050688' date='Ja... Jan 12 2023, 09:30 AM
mb911
Why not use these?
[url=https://store.jenve... Jan 12 2023, 09:41 AM
ClayPerrine
[quote name='ClayPerrine' post='3050688' date='Ja... Jan 12 2023, 09:50 AM
mb911
[quote name='ClayPerrine' post='3050688' date='J... Jan 12 2023, 09:57 AM
JmuRiz Cool project...I was always wondering about EFI us... Jan 12 2023, 09:06 AM
gereed75 I am going the MFI components route -throttle bodi... Jan 12 2023, 09:16 AM
914_teener Why not just keep the MFI?
I always thought it ... Jan 12 2023, 02:41 PM
ClayPerrine
I always thought it... Jan 12 2023, 03:03 PM
914_teener
I always thought i... Jan 12 2023, 03:43 PM
mb911
I always thought it... Jan 12 2023, 03:59 PM
mate914 I would like to see a complete list of parts neede... Jan 12 2023, 04:15 PM
mb911
I would like to see a complete list of parts need... Jan 12 2023, 05:06 PM
Superhawk996
I would like to see a complete list of parts nee... Jan 12 2023, 05:21 PM
mb911
[quote name='mb911' post='3050795' date='Jan 12 2... Jan 12 2023, 06:20 PM
mepstein Ben put the engine together from scratch, using pa... Jan 12 2023, 04:46 PM
rudedude My mfi cars start much easier than is described ab... Jan 12 2023, 04:47 PM
Superhawk996 Anyone priced a MFI rebuild? :blowup: Jan 12 2023, 05:04 PM
mb911
Yes itâ... Jan 12 2023, 05:10 PM
mb911 For you viewing pleasure Jan 12 2023, 08:19 PM
Root_Werks :blink:
According to my wife, boss, coworkers an... Jan 12 2023, 11:10 PM
mb911
:blink:
According to my wife, boss, coworkers a... Jan 13 2023, 06:07 AM
gereed75 Ben. On your motor, what was covering/plugging th... Jan 13 2023, 09:34 AM
mb911
Ben. On your motor, what was covering/plugging t... Jan 13 2023, 11:16 AM
mb911 Vacuum fittings selected. I will have to drill and... Jan 13 2023, 03:14 PM
gereed75
Vacuum fittings selected. I will have to drill an... Jan 13 2023, 04:38 PM
mb911
[quote name='mb911' post='3050957' date='Jan 13 2... Jan 14 2023, 05:54 AM
r_towle I’m a bit confused.
Newbie to modifying a 6 here... Jan 14 2023, 01:43 PM
mb911
I’m a bit confused.
Newbie to modifying a 6 her... Jan 14 2023, 05:30 PM
gereed75 The 930 heads do not have an injector port like th... Jan 14 2023, 04:51 PM
rhodyguy What becomes of float bowls and other carb related... Jan 14 2023, 05:04 PM
mb911
What becomes of float bowls and other carb relate... Jan 14 2023, 05:30 PM
mb911 Went a different route on vacuum tubes. Drill .100... Jan 16 2023, 04:42 PM
mb911 Equal length vacuum lines and manifold for a clean... Feb 11 2023, 07:30 PM
technicalninja You will need to check the map signal you get off ... Feb 11 2023, 08:47 PM
mb911
You will need to check the map signal you get off... Feb 12 2023, 05:44 AM
JmuRiz Do you need MFI heads for this to work? Feb 17 2023, 08:52 AM
mb911
Yes Feb 17 2023, 03:38 PM
sixnotfour
Easy bu... Feb 17 2023, 05:39 PM
mb911
Easy b... Feb 17 2023, 06:41 PM
rick 918-S
[quote name='sixnotfour' post='3058893' date='Feb... Feb 17 2023, 07:22 PM
Easy b... Feb 17 2023, 07:32 PM
sixnotfour
[quote name='sixnotfour' post='3058893' date='Feb... Feb 17 2023, 07:52 PM
mb911 RE: EFI project has started Feb 17 2023, 03:39 PM
technicalninja
You do very nice work, Sir.
What is the upper... Feb 17 2023, 08:05 PM
mb911
What is the uppe... Feb 17 2023, 08:19 PM
JmuRiz Cool fuel and vacuum block, right.
Jpnovak’s se... Feb 17 2023, 08:28 PM
mb911
Jpnovak’s s... Feb 18 2023, 06:38 AM
mb911 Nothing much going on here. I need to purchase the... Apr 23 2023, 05:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 12:05 AM |
