Rear camber shims, Rear camber shims number and thickness |
pistonboy |
Jan 9 2023, 12:14 AM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
In the past, I removed rear camber shims from my car. Since then, trailing arm bushings have been replaced and I need to return the shim stack to its original thickness. I usually keep a record of such changes, but apparently I failed to record it or keep the old shims. I believe all shims were the same thickness. Can anyone measure the thickness of a spare shim they have? Also, how many shims are installed at each wheel? I suspect all vehicles had the same number of shims, though not guaranteed. I have replacement shims from 914 Rubber which are of varying thickness, but I believe the original shims were all the same thickness. Thank you. Sincerely, Shimless Jim |
NARP74 |
Jan 9 2023, 01:12 PM
Senior Member Group: Members Posts: 1,072 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
OK, now we need a breakout thread.
Ride height and corner balance have been on my list to play with for a while. How do you corner balance w/o scales? |
ChrisFoley |
Jan 12 2023, 11:54 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
OK, now we need a breakout thread. Ride height and corner balance have been on my list to play with for a while. How do you corner balance w/o scales? The first time I cornerbalanced my race car I used a long handled square nose shovel. I went around the car and put the shovel under each wheel to compare the effort required to lift each corner of the car. (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Jan 12 2023, 01:10 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The first time I cornerbalanced my race car I used a long handled square nose shovel. I went around the car and put the shovel under each wheel to compare the effort required to lift each corner of the car. (IMG:style_emoticons/default/idea.gif) You could use a spring scale on the end of that lever to get some usable numbers. (IMG:style_emoticons/default/idea.gif) Attached image(s) |
ChrisFoley |
Jan 13 2023, 04:28 AM
The first time I cornerbalanced my race car I used a long handled square nose shovel. I went around the car and put the shovel under each wheel to compare the effort required to lift each corner of the car. (IMG:style_emoticons/default/idea.gif) You could use a spring scale on the end of that lever to get some usable numbers. (IMG:style_emoticons/default/idea.gif) Hi-tech! (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:37 AM |
