> EFI project has started
mb911
post Jan 11 2023, 08:11 PM
Just a quick update. MFI to EFI bungs are in and will be using the carbs will just be throttle bodies and port injection.
Have at those questionsAttached Image
mb911
post Jan 13 2023, 03:14 PM
Vacuum fittings selected. I will have to drill and tap each manifold to get a good signal for the MAP sensor Attached Image
mb911   EFI project has started   Jan 11 2023, 08:11 PM
Superhawk996   You’re being a tease What ECU? Planning to ru...   Jan 12 2023, 12:09 AM
mb911   Phil, Gonna use mega squirt. I have base map’s ...   Jan 12 2023, 05:17 AM
JamesM   Phil, Gonna use mega squirt. I have base map’s...   Jan 12 2023, 11:00 AM
bbrock   :popcorn: Will be watching closely. I'm still...   Jan 12 2023, 08:38 AM
ClayPerrine   Why not use these? [url=https://store.jenvey...   Jan 12 2023, 08:51 AM
Superhawk996   Why not use these? [url=https://store.jenve...   Jan 12 2023, 09:17 AM
ClayPerrine   [quote name='ClayPerrine' post='3050688' date='Ja...   Jan 12 2023, 09:30 AM
mb911   Why not use these? [url=https://store.jenve...   Jan 12 2023, 09:41 AM
ClayPerrine   [quote name='ClayPerrine' post='3050688' date='Ja...   Jan 12 2023, 09:50 AM
mb911   [quote name='ClayPerrine' post='3050688' date='J...   Jan 12 2023, 09:57 AM
JmuRiz   Cool project...I was always wondering about EFI us...   Jan 12 2023, 09:06 AM
gereed75   I am going the MFI components route -throttle bodi...   Jan 12 2023, 09:16 AM
914_teener   Why not just keep the MFI? I always thought it ...   Jan 12 2023, 02:41 PM
ClayPerrine   Why not just keep the MFI? I always thought it...   Jan 12 2023, 03:03 PM
914_teener   Why not just keep the MFI? I always thought i...   Jan 12 2023, 03:43 PM
mb911   Why not just keep the MFI? I always thought it...   Jan 12 2023, 03:59 PM
mate914   I would like to see a complete list of parts neede...   Jan 12 2023, 04:15 PM
mb911   I would like to see a complete list of parts need...   Jan 12 2023, 05:06 PM
Superhawk996   I would like to see a complete list of parts nee...   Jan 12 2023, 05:21 PM
mb911   [quote name='mb911' post='3050795' date='Jan 12 2...   Jan 12 2023, 06:20 PM
mepstein   Ben put the engine together from scratch, using pa...   Jan 12 2023, 04:46 PM
rudedude   My mfi cars start much easier than is described ab...   Jan 12 2023, 04:47 PM
Superhawk996   Anyone priced a MFI rebuild? :blowup:   Jan 12 2023, 05:04 PM
mb911   Anyone priced a MFI rebuild? :blowup: Yes itâ...   Jan 12 2023, 05:10 PM
mb911   For you viewing pleasure   Jan 12 2023, 08:19 PM
Root_Werks   :blink: According to my wife, boss, coworkers an...   Jan 12 2023, 11:10 PM
mb911   :blink: According to my wife, boss, coworkers a...   Jan 13 2023, 06:07 AM
gereed75   Ben. On your motor, what was covering/plugging th...   Jan 13 2023, 09:34 AM
mb911   Ben. On your motor, what was covering/plugging t...   Jan 13 2023, 11:16 AM
mb911   Vacuum fittings selected. I will have to drill and...   Jan 13 2023, 03:14 PM
gereed75   Vacuum fittings selected. I will have to drill an...   Jan 13 2023, 04:38 PM
mb911   [quote name='mb911' post='3050957' date='Jan 13 2...   Jan 14 2023, 05:54 AM
r_towle   I’m a bit confused. Newbie to modifying a 6 here...   Jan 14 2023, 01:43 PM
mb911   I’m a bit confused. Newbie to modifying a 6 her...   Jan 14 2023, 05:30 PM
gereed75   The 930 heads do not have an injector port like th...   Jan 14 2023, 04:51 PM
rhodyguy   What becomes of float bowls and other carb related...   Jan 14 2023, 05:04 PM
mb911   What becomes of float bowls and other carb relate...   Jan 14 2023, 05:30 PM
mb911   Went a different route on vacuum tubes. Drill .100...   Jan 16 2023, 04:42 PM
mb911   Equal length vacuum lines and manifold for a clean...   Feb 11 2023, 07:30 PM
technicalninja   You will need to check the map signal you get off ...   Feb 11 2023, 08:47 PM
mb911   You will need to check the map signal you get off...   Feb 12 2023, 05:44 AM
JmuRiz   Do you need MFI heads for this to work?   Feb 17 2023, 08:52 AM
mb911   Do you need MFI heads for this to work? Yes   Feb 17 2023, 03:38 PM
sixnotfour   Do you need MFI heads for this to work? Easy bu...   Feb 17 2023, 05:39 PM
mb911   Do you need MFI heads for this to work? Easy b...   Feb 17 2023, 06:41 PM
rick 918-S   [quote name='sixnotfour' post='3058893' date='Feb...   Feb 17 2023, 07:22 PM
mepstein   Do you need MFI heads for this to work? Easy b...   Feb 17 2023, 07:32 PM
sixnotfour   [quote name='sixnotfour' post='3058893' date='Feb...   Feb 17 2023, 07:52 PM
mb911   RE: EFI project has started   Feb 17 2023, 03:39 PM
technicalninja   You do very nice work, Sir. What is the upper...   Feb 17 2023, 08:05 PM
mb911   You do very nice work, Sir. What is the uppe...   Feb 17 2023, 08:19 PM
JmuRiz   Cool fuel and vacuum block, right. Jpnovak’s se...   Feb 17 2023, 08:28 PM
mb911   Cool fuel and vacuum block, right. Jpnovak’s s...   Feb 18 2023, 06:38 AM
mb911   Nothing much going on here. I need to purchase the...   Apr 23 2023, 05:45 PM
- Lo-Fi Version Time is now: 12th March 2026 - 12:05 AM
