> EFI project has started
mb911
post Jan 11 2023, 08:11 PM
Just a quick update. MFI to EFI bungs are in and will be using the carbs will just be throttle bodies and port injection.
Have at those questionsAttached Image
r_towle
post Jan 14 2023, 01:43 PM
Custom Member
I’m a bit confused.
Newbie to modifying a 6 here, but I have webers and will be doing some sort of fuel injection going forward due to car sitting for months in winter, not DD etc etc
So, mine is a 3.0 that I assume was using the old FI, but that is all gone.
Motor came with webers.
My question is, can I follow you, copy you, without modifying my heads in any way? I’m happy to get adapters for the injectors…but I’m concerned with head changes.
mb911
post Jan 14 2023, 05:30 PM
QUOTE(r_towle @ Jan 14 2023, 11:43 AM) *
I’m a bit confused.
Sorry you would need MFI heads to do this or some machine work
mb911   EFI project has started   Jan 11 2023, 08:11 PM
Superhawk996   You’re being a tease What ECU? Planning to ru...   Jan 12 2023, 12:09 AM
mb911   Phil, Gonna use mega squirt. I have base map’s ...   Jan 12 2023, 05:17 AM
JamesM   Phil, Gonna use mega squirt. I have base map’s...   Jan 12 2023, 11:00 AM
bbrock   :popcorn: Will be watching closely. I'm still...   Jan 12 2023, 08:38 AM
ClayPerrine   Why not use these? [url=https://store.jenvey...   Jan 12 2023, 08:51 AM
Superhawk996   Why not use these? [url=https://store.jenve...   Jan 12 2023, 09:17 AM
ClayPerrine   [quote name='ClayPerrine' post='3050688' date='Ja...   Jan 12 2023, 09:30 AM
mb911   Why not use these? [url=https://store.jenve...   Jan 12 2023, 09:41 AM
ClayPerrine   [quote name='ClayPerrine' post='3050688' date='Ja...   Jan 12 2023, 09:50 AM
mb911   [quote name='ClayPerrine' post='3050688' date='J...   Jan 12 2023, 09:57 AM
JmuRiz   Cool project...I was always wondering about EFI us...   Jan 12 2023, 09:06 AM
gereed75   I am going the MFI components route -throttle bodi...   Jan 12 2023, 09:16 AM
914_teener   Why not just keep the MFI? I always thought it ...   Jan 12 2023, 02:41 PM
ClayPerrine   Why not just keep the MFI? I always thought it...   Jan 12 2023, 03:03 PM
914_teener   Why not just keep the MFI? I always thought i...   Jan 12 2023, 03:43 PM
mb911   Why not just keep the MFI? I always thought it...   Jan 12 2023, 03:59 PM
mate914   I would like to see a complete list of parts neede...   Jan 12 2023, 04:15 PM
mb911   I would like to see a complete list of parts need...   Jan 12 2023, 05:06 PM
Superhawk996   I would like to see a complete list of parts nee...   Jan 12 2023, 05:21 PM
mb911   [quote name='mb911' post='3050795' date='Jan 12 2...   Jan 12 2023, 06:20 PM
mepstein   Ben put the engine together from scratch, using pa...   Jan 12 2023, 04:46 PM
rudedude   My mfi cars start much easier than is described ab...   Jan 12 2023, 04:47 PM
Superhawk996   Anyone priced a MFI rebuild? :blowup:   Jan 12 2023, 05:04 PM
mb911   Anyone priced a MFI rebuild? :blowup: Yes itâ...   Jan 12 2023, 05:10 PM
mb911   For you viewing pleasure   Jan 12 2023, 08:19 PM
Root_Werks   :blink: According to my wife, boss, coworkers an...   Jan 12 2023, 11:10 PM
mb911   :blink: According to my wife, boss, coworkers a...   Jan 13 2023, 06:07 AM
gereed75   Ben. On your motor, what was covering/plugging th...   Jan 13 2023, 09:34 AM
mb911   Ben. On your motor, what was covering/plugging t...   Jan 13 2023, 11:16 AM
mb911   Vacuum fittings selected. I will have to drill and...   Jan 13 2023, 03:14 PM
gereed75   Vacuum fittings selected. I will have to drill an...   Jan 13 2023, 04:38 PM
mb911   [quote name='mb911' post='3050957' date='Jan 13 2...   Jan 14 2023, 05:54 AM
r_towle   I’m a bit confused. Newbie to modifying a 6 here...   Jan 14 2023, 01:43 PM
mb911   I’m a bit confused. Newbie to modifying a 6 her...   Jan 14 2023, 05:30 PM
gereed75   The 930 heads do not have an injector port like th...   Jan 14 2023, 04:51 PM
rhodyguy   What becomes of float bowls and other carb related...   Jan 14 2023, 05:04 PM
mb911   What becomes of float bowls and other carb relate...   Jan 14 2023, 05:30 PM
mb911   Went a different route on vacuum tubes. Drill .100...   Jan 16 2023, 04:42 PM
mb911   Equal length vacuum lines and manifold for a clean...   Feb 11 2023, 07:30 PM
technicalninja   You will need to check the map signal you get off ...   Feb 11 2023, 08:47 PM
mb911   You will need to check the map signal you get off...   Feb 12 2023, 05:44 AM
JmuRiz   Do you need MFI heads for this to work?   Feb 17 2023, 08:52 AM
mb911   Do you need MFI heads for this to work? Yes   Feb 17 2023, 03:38 PM
sixnotfour   Do you need MFI heads for this to work? Easy bu...   Feb 17 2023, 05:39 PM
mb911   Do you need MFI heads for this to work? Easy b...   Feb 17 2023, 06:41 PM
rick 918-S   [quote name='sixnotfour' post='3058893' date='Feb...   Feb 17 2023, 07:22 PM
mepstein   Do you need MFI heads for this to work? Easy b...   Feb 17 2023, 07:32 PM
sixnotfour   [quote name='sixnotfour' post='3058893' date='Feb...   Feb 17 2023, 07:52 PM
mb911   RE: EFI project has started   Feb 17 2023, 03:39 PM
technicalninja   You do very nice work, Sir. What is the upper...   Feb 17 2023, 08:05 PM
mb911   You do very nice work, Sir. What is the uppe...   Feb 17 2023, 08:19 PM
JmuRiz   Cool fuel and vacuum block, right. Jpnovak’s se...   Feb 17 2023, 08:28 PM
mb911   Cool fuel and vacuum block, right. Jpnovak’s s...   Feb 18 2023, 06:38 AM
mb911   Nothing much going on here. I need to purchase the...   Apr 23 2023, 05:45 PM
- Lo-Fi Version Time is now: 12th March 2026 - 12:04 AM
