SVG223 |
Member ![]() ![]() Group: Members Posts: 115 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None ![]() |
In the middle of rebuilding/bleeding the brakes and the parking brake warning light is flashing while doing test drives and won't shut off. After checking the parking brake switch I do a little research and read about the brake pressure warning switch on the master cylinder which has a reset button. I'm thinking about how often I might have to reset the thing before I'm done with the brakes. What about cutting the wire to the switch until I decide to rebuild/replace the master cylinder, then reattach it? I don't think I need a flashing light to tell me that I have low brake pressure, that should be obvious.
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,437 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
OK - the master cylinder is under the car, right behind the front wheels, below the gas tank. You can access it by jacking the car up and if you still have the steering rack protector plate installed, remove that (4 bolts) and the master cylinder is on full display. (IMG:style_emoticons/default/beerchug.gif)
SVG223 |
Lo-Fi Version | Time is now: 18th September 2025 - 06:58 PM |
