Engine position, Questions related to Subaru Swap |
Lilchopshop |
Jan 27 2023, 11:02 AM
Member Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
Hi All,
I’m sure this has been discussed in other posts here, but I’m not having luck finding them…. I’m building a Suby-swapped 914. I’m using the 2.2L motor and 5MT from a ‘99 Legacy. I want to build my own engine cradle and I might make my own engine mounts that are tied into the rear suspension ears similar to what @tygaboy is doing on his Ferrari swap. I don’t mind cutting into the trunk for clearance, but I still want a functional trunk and storage for the targa top. I’m at the point now of trying to find the optimum position for the engine/tranny and I have the following questions: 1. Crankshaft angle; I’ve seen others try to keep the angle parallel to the ground. If I do this, the engine will be very low unless I make big cuts into the trunk floor for the transmission. What should I be looking for relative to engine height and crankshaft angle? 2. CV angle; I know that less angle is better, but the output shafts on the Suby transmission are very far forward. If I align these to the trailing arms, the whole engine/transmission ends up very far back leaving no room for a muffler, making intake plumbing tricky and shifting the CG of the car rearwards. I’m planning to get custom axles that will use the Subaru inner cv joints and the 914 cv joints at the wheels. With the mock-up I am doing now, i have things in a position where there is just enough room to fit a muffler behind the tranny and gives me enough room between the stock intake manifold and the rear of the engine bay. However, this position has the cv axles sweeping backwards at about 15.5 degrees when the trailing arms are horizontal. Does this seem like too much? Anything else I should be considering here? |
tygaboy |
Jan 27 2023, 11:37 AM
914 Guru Group: Members Posts: 5,311 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I can't comment on crankshaft angle but there've been so many Subbie conversions, I can't help but think you'll get a bunch of comments on what works.
But on the CVs: You should be able to get info on the operating angle range of the CVs. Just be sure you stay within that range. And you don't need to have the output shafts even with the trailing arm inputs. My LS car's axles still point forward, even after I moved the drive train forward 1.5". They also angle up from the trans to the trailing arms. Again, so long as you're "in range", you should be fine. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:15 AM |
