| Type 47 |
Jan 30 2023, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
| Superhawk996 |
Jan 30 2023, 05:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Is the cover intended to catch this leak . . . (IMG:style_emoticons/default/av-943.gif) That does seem to be what they actually do . . . . or is something not right? Defiantly not right. brant is referring to the o-ring for the housing but there is also a seal in that assembly that seals to the shift rod that is sliding in/out of the housing and as it pivots fore/aft. Based on where your leak is, I think it’s that internal seal. I know there are other threads on this - probably with seal info for replacement. |
Type 47 Is this normal or not normal Jan 30 2023, 04:30 PM
brant there is an o-ring on the cover/housing...
you can... Jan 30 2023, 04:41 PM
930cabman
Is the cover intended to catch this leak or is ... Jan 30 2023, 05:40 PM
r_towle There is an o-ring on the body to tranny
There is ... Jan 30 2023, 05:38 PM
Superhawk996 It’s in PET
Jan 30 2023, 05:39 PM
Superhawk996 Had that bastard cover dump water and stinky trans... Jan 30 2023, 05:57 PM
rhodyguy Plan replacing the ball cup bushing while you’re... Jan 30 2023, 06:08 PM
Craigers17 Here's a Pelican DIY article:
https://www.pel... Jan 30 2023, 06:18 PM
Type 47 Thanks guys!!! I will start reading t... Jan 30 2023, 06:54 PM
r_towle Seal and o-ring are part of the tranny gasket set.... Jan 30 2023, 10:41 PM
bdstone914
Seal and o-ring are part of the tranny gasket set... Jan 31 2023, 08:16 AM
r_towle
Seal and o-ring are part of the tranny gasket se... Jan 31 2023, 06:15 PM
bdstone914
Seal and o-ring are part of the tranny gasket set... Jan 31 2023, 08:22 AM
rhodyguy The cover has a small hole in the bottom side that... Jan 31 2023, 07:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:00 AM |
