| Motosan |
Feb 4 2023, 12:57 PM
Newbie ![]() Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
I have noticed that the air box connection is loose after getting to work on the car. Took the box off, changed the filter and vacuum hoses but noticed the connection isn’t tight after getting everything back together. I’m not married to the stock box if there is a better solution but just not sure if this connection is a wear item or I’m missing a way to tighten this connection.
Thanks! Attached thumbnail(s) |
| 914sgofast2 |
Feb 4 2023, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface.
| Superhawk996 |
Feb 4 2023, 06:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,102 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface. (IMG:style_emoticons/default/agree.gif) Tried to find part in PET - it is vague as can be on the air box throttle body for the various engines - no clear pictures or part number |
Motosan Air box connection Feb 4 2023, 12:57 PM
emerygt350 You mean you can't tighten that flat head bolt... Feb 4 2023, 12:58 PM
Motosan
You mean you can't tighten that flat head bol... Feb 4 2023, 01:05 PM
emerygt350 Are you doing new hoses or something? Feb 4 2023, 01:01 PM
rhodyguy I would WTB a dif clamp. Your’s looks bent to th... Feb 4 2023, 01:12 PM
Motosan
I would WTB a dif clamp. Your’s looks bent to t... Feb 4 2023, 01:20 PM
r_towle Add a clamp, or new adhesive.
It should be tight t... Feb 4 2023, 02:08 PM
Cairo94507 I thought (on my '73 2.0) there was a rubber s... Feb 4 2023, 02:13 PM
emerygt350 I would just bend that metal piece back into shape... Feb 4 2023, 02:40 PM
Superhawk996
I would just bend that metal piece back into shap... Feb 4 2023, 06:10 PM
emerygt350
I would just bend that metal piece back into sha... Feb 5 2023, 07:17 AM
914sgofast2 914Rubber sells them. It’s called a 2 liter flan... Feb 5 2023, 01:09 PM
Superhawk996
914Rubber sells them. It’s called a 2 liter fla... Feb 5 2023, 01:26 PM
mgphoto Mine has a habit of popping out of the flange, I a... Feb 8 2023, 06:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd October 2026 - 06:36 PM |
