| Motosan |
Feb 4 2023, 12:57 PM
Newbie ![]() Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
I have noticed that the air box connection is loose after getting to work on the car. Took the box off, changed the filter and vacuum hoses but noticed the connection isn’t tight after getting everything back together. I’m not married to the stock box if there is a better solution but just not sure if this connection is a wear item or I’m missing a way to tighten this connection.
Thanks! Attached thumbnail(s) |
| emerygt350 |
Feb 4 2023, 02:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,763 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would just bend that metal piece back into shape. No need to go crazy with it.
Also, be careful as you replace the hoses. Many of the diagrams out there do not show the correct piping. Particularly for the decel valve. |
| Superhawk996 |
Feb 4 2023, 06:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,102 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| emerygt350 |
Feb 5 2023, 07:17 AM
Motosan Air box connection Feb 4 2023, 12:57 PM
emerygt350 You mean you can't tighten that flat head bolt... Feb 4 2023, 12:58 PM
Motosan
You mean you can't tighten that flat head bol... Feb 4 2023, 01:05 PM
emerygt350 Are you doing new hoses or something? Feb 4 2023, 01:01 PM
rhodyguy I would WTB a dif clamp. Your’s looks bent to th... Feb 4 2023, 01:12 PM
Motosan
I would WTB a dif clamp. Your’s looks bent to t... Feb 4 2023, 01:20 PM
r_towle Add a clamp, or new adhesive.
It should be tight t... Feb 4 2023, 02:08 PM
Cairo94507 I thought (on my '73 2.0) there was a rubber s... Feb 4 2023, 02:13 PM
914sgofast2 I think you need to replace the rubber seal that s... Feb 4 2023, 04:30 PM
Superhawk996
I think you need to replace the rubber seal that ... Feb 4 2023, 06:17 PM
914sgofast2 914Rubber sells them. It’s called a 2 liter flan... Feb 5 2023, 01:09 PM
Superhawk996
914Rubber sells them. It’s called a 2 liter fla... Feb 5 2023, 01:26 PM
mgphoto Mine has a habit of popping out of the flange, I a... Feb 8 2023, 06:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd October 2026 - 06:37 PM |
