| GeorgeKopf |
Feb 7 2023, 09:15 AM
Member ![]() ![]() Group: Members Posts: 260 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
My chassis is at the stage where I have to make a decision on whether or not to roll the wheel well lip. I will be running the 4 lug 2.0 Fuchs (15 x 5.5).
I searched the forums but couldn't find an answer to my exact question. What is the widest tire I can run with and without rolling the wheel well lip? Does it make any difference? I am interested in maximizing traction but I'm not willing to go to flared fenders. Thanks. George |
| GeorgeKopf |
Feb 7 2023, 10:55 AM
To provide a little more context.
My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George |
| mihai914 |
Feb 7 2023, 12:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
To provide a little more context. My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George If you're at this stage of the project, you might as well roll the fenders if you're considering anything over 195/65/15 and if it's not a big expense. The way the body was assembled really dictates what will fit on your car without rubbing. If speedo accuracy is a concern, you can also have the speedo recalibrated to fit your new tires. And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. |
GeorgeKopf Max Tire Width 4 Lug Fuchs? Feb 7 2023, 09:15 AM
parrish911 I run 205/50 15 and did not have to roll the rear ... Feb 7 2023, 09:18 AM
NARP74 Might depend on your frame. Mine is a little off ... Feb 7 2023, 09:34 AM
dr914@autoatlanta.com on the 23 standard offset 205/60x15 but will need ... Feb 7 2023, 09:43 AM
Root_Werks Could also start to look "funny" if you ... Feb 7 2023, 10:05 AM
rhodyguy I found the 205s, and the ballooning from the tire... Feb 7 2023, 10:09 AM
Chris914n6
And most of all, JamesJ is right, threadwear rat... Feb 7 2023, 03:17 PM
914_teener
And most of all, JamesJ is right, threadwear ra... Feb 7 2023, 03:24 PM
mihai914
[quote name='mihai914' post='3056239' date='Feb 7... Feb 7 2023, 03:34 PM
JamesJ
And most of all, JamesJ is right, threadwear ra... Feb 7 2023, 06:45 PM
Chris914n6
Respectfully, ahhhh, no.
My bad. Those came out ... Feb 7 2023, 07:41 PM
Jamie
My chassis is ... Feb 7 2023, 03:13 PM
JamesJ Myth: the wider the stickier.
Look for a low tread... Feb 7 2023, 11:34 AM
rhodyguy On 5 1/2” wheels. I imagine disregarding this co... Feb 7 2023, 12:21 PM
Chris914n6 You only need to roll the rear fender 1/2" or... Feb 7 2023, 12:29 PM
rhodyguy The use warnings are enough for me to forget the V... Feb 7 2023, 05:56 PM
bkrantz I put 195/65-15 on stock Fuchs four lug wheels. W... Feb 7 2023, 09:17 PM
Dave_Darling One reason why you don't find definitive answe... Feb 8 2023, 09:16 PM
GeorgeKopf Thank you everybody for the information and insigh... Feb 11 2023, 11:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 12:22 AM |
