| GeorgeKopf |
Feb 7 2023, 09:15 AM
Member ![]() ![]() Group: Members Posts: 260 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
My chassis is at the stage where I have to make a decision on whether or not to roll the wheel well lip. I will be running the 4 lug 2.0 Fuchs (15 x 5.5).
I searched the forums but couldn't find an answer to my exact question. What is the widest tire I can run with and without rolling the wheel well lip? Does it make any difference? I am interested in maximizing traction but I'm not willing to go to flared fenders. Thanks. George |
| GeorgeKopf |
Feb 7 2023, 10:55 AM
To provide a little more context.
My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George |
| Jamie |
Feb 7 2023, 03:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
To provide a little more context. My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George I've been running 205/65/15 Michelins on original steel 5.5" wheels for many years, no wheel rub in back but 12MM spacers in front to eliminate inner rub full lock. Odometer is nearly correct when compared to GPS for check. |
GeorgeKopf Max Tire Width 4 Lug Fuchs? Feb 7 2023, 09:15 AM
parrish911 I run 205/50 15 and did not have to roll the rear ... Feb 7 2023, 09:18 AM
NARP74 Might depend on your frame. Mine is a little off ... Feb 7 2023, 09:34 AM
dr914@autoatlanta.com on the 23 standard offset 205/60x15 but will need ... Feb 7 2023, 09:43 AM
Root_Werks Could also start to look "funny" if you ... Feb 7 2023, 10:05 AM
rhodyguy I found the 205s, and the ballooning from the tire... Feb 7 2023, 10:09 AM
mihai914
My chassis is ... Feb 7 2023, 12:58 PM
Chris914n6
And most of all, JamesJ is right, threadwear rat... Feb 7 2023, 03:17 PM
914_teener
And most of all, JamesJ is right, threadwear ra... Feb 7 2023, 03:24 PM
mihai914
[quote name='mihai914' post='3056239' date='Feb 7... Feb 7 2023, 03:34 PM
JamesJ
And most of all, JamesJ is right, threadwear ra... Feb 7 2023, 06:45 PM
Chris914n6
Respectfully, ahhhh, no.
My bad. Those came out ... Feb 7 2023, 07:41 PM
JamesJ Myth: the wider the stickier.
Look for a low tread... Feb 7 2023, 11:34 AM
rhodyguy On 5 1/2” wheels. I imagine disregarding this co... Feb 7 2023, 12:21 PM
Chris914n6 You only need to roll the rear fender 1/2" or... Feb 7 2023, 12:29 PM
rhodyguy The use warnings are enough for me to forget the V... Feb 7 2023, 05:56 PM
bkrantz I put 195/65-15 on stock Fuchs four lug wheels. W... Feb 7 2023, 09:17 PM
Dave_Darling One reason why you don't find definitive answe... Feb 8 2023, 09:16 PM
GeorgeKopf Thank you everybody for the information and insigh... Feb 11 2023, 11:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 12:24 AM |
