| GeorgeKopf |
Feb 7 2023, 09:15 AM
Member ![]() ![]() Group: Members Posts: 260 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
My chassis is at the stage where I have to make a decision on whether or not to roll the wheel well lip. I will be running the 4 lug 2.0 Fuchs (15 x 5.5).
I searched the forums but couldn't find an answer to my exact question. What is the widest tire I can run with and without rolling the wheel well lip? Does it make any difference? I am interested in maximizing traction but I'm not willing to go to flared fenders. Thanks. George |
| GeorgeKopf |
Feb 7 2023, 10:55 AM
To provide a little more context.
My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George |
| mihai914 |
Feb 7 2023, 12:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
To provide a little more context. My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George If you're at this stage of the project, you might as well roll the fenders if you're considering anything over 195/65/15 and if it's not a big expense. The way the body was assembled really dictates what will fit on your car without rubbing. If speedo accuracy is a concern, you can also have the speedo recalibrated to fit your new tires. And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. |
| Chris914n6 |
Feb 7 2023, 03:17 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,536 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. You have it backwards. A 195 or 185 is going to be the high mileage econo car tire size. I have seen 205 in the stickier <400. Something <200 is going to be a 205/50. 205/50-15 is common with track Miatas. |
| 914_teener |
Feb 7 2023, 03:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. You have it backwards. A 195 or 185 is going to be the high mileage econo car tire size. I have seen 205 in the stickier <400. Something <200 is going to be a 205/50. 205/50-15 is common with track Miatas. I ran 205/55's and it barely cleared on one side. As has been echoed by many...most all 914's normally don't space out evenly on each side of the tires. The other thing I'd suggest before you go with the wider set up is that you check and make sure the rear is aligned well and that your bushings are if good shape. If not...or unkown now is a good time to replace. BTDT. |
GeorgeKopf Max Tire Width 4 Lug Fuchs? Feb 7 2023, 09:15 AM
parrish911 I run 205/50 15 and did not have to roll the rear ... Feb 7 2023, 09:18 AM
NARP74 Might depend on your frame. Mine is a little off ... Feb 7 2023, 09:34 AM
dr914@autoatlanta.com on the 23 standard offset 205/60x15 but will need ... Feb 7 2023, 09:43 AM
Root_Werks Could also start to look "funny" if you ... Feb 7 2023, 10:05 AM
rhodyguy I found the 205s, and the ballooning from the tire... Feb 7 2023, 10:09 AM
mihai914
[quote name='mihai914' post='3056239' date='Feb 7... Feb 7 2023, 03:34 PM
JamesJ
And most of all, JamesJ is right, threadwear ra... Feb 7 2023, 06:45 PM
Chris914n6
Respectfully, ahhhh, no.
My bad. Those came out ... Feb 7 2023, 07:41 PM
Jamie
My chassis is ... Feb 7 2023, 03:13 PM
JamesJ Myth: the wider the stickier.
Look for a low tread... Feb 7 2023, 11:34 AM
rhodyguy On 5 1/2” wheels. I imagine disregarding this co... Feb 7 2023, 12:21 PM
Chris914n6 You only need to roll the rear fender 1/2" or... Feb 7 2023, 12:29 PM
rhodyguy The use warnings are enough for me to forget the V... Feb 7 2023, 05:56 PM
bkrantz I put 195/65-15 on stock Fuchs four lug wheels. W... Feb 7 2023, 09:17 PM
Dave_Darling One reason why you don't find definitive answe... Feb 8 2023, 09:16 PM
GeorgeKopf Thank you everybody for the information and insigh... Feb 11 2023, 11:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 12:24 AM |
