| campbellcj |
Feb 7 2023, 02:13 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,717 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Hi All -
I'm fairly sure my alternator (-6) just crapped-out and want to confirm that's the problem. Very abruptly my dash voltmeter dropped to around 10-11V when running, regardless of revs, vs the normal 13.8 or whatnot. The battery did not seem to be charging, but was just about 5 yrs old so I replaced it, however no change in the voltmeter reading. All wiring and grounds look intact, same as before the issue started. The car starts and runs normally with a charged battery. Is there an easy way to confirm it is or isn't the alternator with the engine still in the car? Thanks! |
| Superhawk996 |
Feb 7 2023, 11:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,105 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
You can full field the alternator momentarily - if output on B+ isn’t well above 14v alternator is bad.
http://forums.pelicanparts.com/porsche-911...agram-help.html See post #12 from spoke http://www.914world.com/bbs2/index.php?showtopic=64142 The terminals he is referring to are D+ and DF. Per his post - if the schematics and the terminal descriptions doesn’t make sense to you, have FLAPS test it, but as you know, that entails the PITA of removing the alternator 1st to test it. |
campbellcj Testing -6 alternator/regulator in car? Feb 7 2023, 02:13 PM
troth
Hi All -
I'm fairly sure my alternator (-6) ... Feb 7 2023, 09:08 PM
campbellcj Thanks guys, very helpful and with so much interne... Feb 9 2023, 10:44 AM
slivel My 914 doesn't get driven much and I do keep a... Feb 9 2023, 11:58 AM
campbellcj Well my son had my/our multimeter with him at coll... Feb 20 2023, 03:50 PM
Superhawk996 Full field it.
If it makes 14v or more then the ... Feb 20 2023, 08:09 PM
Superhawk996 Duplicate Feb 20 2023, 08:09 PM
campbellcj Got diverted and distracted by a bunch of other no... Sep 17 2023, 12:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 12:04 PM |
