| mb911 |
Jan 11 2023, 08:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| technicalninja |
Feb 11 2023, 08:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
You will need to check the map signal you get off of that block.
All ITB F.I. setups that I have played with required a TPS sensor as we had to run Alpha N below 12-1500 rpm as the map signal looks like an ignition signal at slow speeds. This FI strategy is called blended alpha N/speed density. More compression and big cam profiles made this MAP instability worse. Most systems that I have worked on have 6 and 8 cylinders. The more cylinders you have the smoother the MAP is at low speed. You might be able to run an IAC valve (idle air control) off the block. I usually go with 3/16-1/4" vacuum lines from each runner to gain enough flow for computer controlled idle aspects. Below the smooth signal threshold, the map sensor is not in use, but the IAC valve is, and above the threshold vise-versus. I will commonly run the MAP off of one end of the block and the IAC off the other. Another solution is to enclose both air filters in plenums and add MAF sensors in the entrance to the plenums, but you will significantly reduce the howl that we all love to hear from an ITB set up. 4 cylinder info next. I'm not researching 6 cylinder stuff yet. I saw the Jenvey Heritage ITB for the 4 cylinders that hide the injectors and the TPS inside the unit. The injectors are firing into the intake just below the throttle blades at an angle. These are WAY cool but Jenvey themselves show compatibility with up to E20 which is a deal breaker for me. The little 350 cc injectors are too small IMO as well. On PMBs website the normal Jenvey IDF (non-hidden injectors) are far more affordable. https://pmbperformance.com/products/jenvey-...r-porsche-914-4 My big 4 cylinder with have those, 1050 cc injectors (Injector Dynamics), and run E85. I'm betting the six-cylinder stuff is similar. One final thought... You could be Hybrid! (IMG:style_emoticons/default/w00t.gif) Turn the FI stuff off, pop the venturis and boosters back in, source the fuel off of the return line, and go old school in less than 10 minutes |
mb911 EFI project has started Jan 11 2023, 08:11 PM
Superhawk996 You’re being a tease
What ECU?
Planning to ru... Jan 12 2023, 12:09 AM
mb911 Phil,
Gonna use mega squirt. I have base map’s ... Jan 12 2023, 05:17 AM
JamesM
Phil,
Gonna use mega squirt. I have base map’s... Jan 12 2023, 11:00 AM
bbrock :popcorn: Will be watching closely. I'm still... Jan 12 2023, 08:38 AM
ClayPerrine Why not use these?
[url=https://store.jenvey... Jan 12 2023, 08:51 AM
Superhawk996
Why not use these?
[url=https://store.jenve... Jan 12 2023, 09:17 AM
ClayPerrine
[quote name='ClayPerrine' post='3050688' date='Ja... Jan 12 2023, 09:30 AM
mb911
Why not use these?
[url=https://store.jenve... Jan 12 2023, 09:41 AM
ClayPerrine
[quote name='ClayPerrine' post='3050688' date='Ja... Jan 12 2023, 09:50 AM
mb911
[quote name='ClayPerrine' post='3050688' date='J... Jan 12 2023, 09:57 AM
JmuRiz Cool project...I was always wondering about EFI us... Jan 12 2023, 09:06 AM
gereed75 I am going the MFI components route -throttle bodi... Jan 12 2023, 09:16 AM
914_teener Why not just keep the MFI?
I always thought it ... Jan 12 2023, 02:41 PM
ClayPerrine
I always thought it... Jan 12 2023, 03:03 PM
914_teener
I always thought i... Jan 12 2023, 03:43 PM
mb911
I always thought it... Jan 12 2023, 03:59 PM
mate914 I would like to see a complete list of parts neede... Jan 12 2023, 04:15 PM
mb911
I would like to see a complete list of parts need... Jan 12 2023, 05:06 PM
Superhawk996
I would like to see a complete list of parts nee... Jan 12 2023, 05:21 PM
mb911
[quote name='mb911' post='3050795' date='Jan 12 2... Jan 12 2023, 06:20 PM
mepstein Ben put the engine together from scratch, using pa... Jan 12 2023, 04:46 PM
rudedude My mfi cars start much easier than is described ab... Jan 12 2023, 04:47 PM
Superhawk996 Anyone priced a MFI rebuild? :blowup: Jan 12 2023, 05:04 PM
mb911
Yes itâ... Jan 12 2023, 05:10 PM
mb911 For you viewing pleasure Jan 12 2023, 08:19 PM
Root_Werks :blink:
According to my wife, boss, coworkers an... Jan 12 2023, 11:10 PM
mb911
:blink:
According to my wife, boss, coworkers a... Jan 13 2023, 06:07 AM
gereed75 Ben. On your motor, what was covering/plugging th... Jan 13 2023, 09:34 AM
mb911
Ben. On your motor, what was covering/plugging t... Jan 13 2023, 11:16 AM
mb911 Vacuum fittings selected. I will have to drill and... Jan 13 2023, 03:14 PM
gereed75
Vacuum fittings selected. I will have to drill an... Jan 13 2023, 04:38 PM
mb911
[quote name='mb911' post='3050957' date='Jan 13 2... Jan 14 2023, 05:54 AM
r_towle I’m a bit confused.
Newbie to modifying a 6 here... Jan 14 2023, 01:43 PM
mb911
I’m a bit confused.
Newbie to modifying a 6 her... Jan 14 2023, 05:30 PM
gereed75 The 930 heads do not have an injector port like th... Jan 14 2023, 04:51 PM
rhodyguy What becomes of float bowls and other carb related... Jan 14 2023, 05:04 PM
mb911
What becomes of float bowls and other carb relate... Jan 14 2023, 05:30 PM
mb911 Went a different route on vacuum tubes. Drill .100... Jan 16 2023, 04:42 PM
mb911 Equal length vacuum lines and manifold for a clean... Feb 11 2023, 07:30 PM
mb911
You will need to check the map signal you get off... Feb 12 2023, 05:44 AM
JmuRiz Do you need MFI heads for this to work? Feb 17 2023, 08:52 AM
mb911
Yes Feb 17 2023, 03:38 PM
sixnotfour
Easy bu... Feb 17 2023, 05:39 PM
mb911
Easy b... Feb 17 2023, 06:41 PM
rick 918-S
[quote name='sixnotfour' post='3058893' date='Feb... Feb 17 2023, 07:22 PM
Easy b... Feb 17 2023, 07:32 PM
sixnotfour
[quote name='sixnotfour' post='3058893' date='Feb... Feb 17 2023, 07:52 PM
mb911 RE: EFI project has started Feb 17 2023, 03:39 PM
technicalninja
You do very nice work, Sir.
What is the upper... Feb 17 2023, 08:05 PM
mb911
What is the uppe... Feb 17 2023, 08:19 PM
JmuRiz Cool fuel and vacuum block, right.
Jpnovak’s se... Feb 17 2023, 08:28 PM
mb911
Jpnovak’s s... Feb 18 2023, 06:38 AM
mb911 Nothing much going on here. I need to purchase the... Apr 23 2023, 05:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 12:03 AM |
