Dck356 |
Newbie ![]() Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States ![]() |
Good evening guys. Recently replaced clutch and flywheel including new rear main seal.
Started car and after it warmed up... oil started leaking out of the flywheel inspection slot. Buddy and I removed all the bits today to see what happened and the rear main seal was torn - looked really bad. The seal had wear on it like it was rubbing against the flywheel. The flywheel is a 215mm stock replacement from AA Products. I'm guessing the seal wasn't seated fully??? What about endplay? Could this have happened if I got the measurement off??? Would like to have as much confidence as possible as to what the issue was before we put it all back together again. Thanks in advance!!! |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,304 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Sounds like the rear main seal wasn’t seated all the way, and/or wasn’t put in straight. Also, what brand was the seal?
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,806 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Sounds like the rear main seal wasn’t seated all the way, and/or wasn’t put in straight. Also, what brand was the seal? (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:25 PM |
