> Jitterbug speedo
gulf908
post Feb 21 2023, 12:33 AM
Region Association: Australia and New Zealand
guys
I have been recently having trouble with my speedo needle
its OK from cold but as the car warms up esp on a warm day,the needle has a bad case of the St Vitus dance between zero kph and about 50 kph and starts doing 270s
after that at a steady 50 kph upwards,its quite stable
the speedo has about 24k kms from a NHS rebuild about 8 1/2 years ago
my mechanic has looked at it and can't see anything obviously wrong with the cable and seems to think its a design fault somewhere
does this sound like the cable or the gauge ?
its becoming a bit alarming to see the needle flicker too much
over to the experts
TIA
Dennis (IMG:style_emoticons/default/biggrin.gif)
914sgofast2
post Feb 21 2023, 11:48 AM
My speedometer did the same thing. It was the cable, not the speedometer. Make sure the cable housing has no sharp curves or bends in it, and that the cable has plenty of lubricant. I discovered that my cable was very sensitive as to how much it was bending coming out of the central transmission tunnel and up to the dash and speedometer. If it wasn't "just right", the speedometer needle would jump all over the place at lower speeds.
- Lo-Fi Version Time is now: 10th December 2025 - 04:06 PM
