First drive running rough, 2.0 weber 40's |
skota23 |
Feb 20 2023, 09:10 AM
Newbie Group: Members Posts: 35 Joined: 28-November 22 From: Madison, WI Member No.: 26,993 Region Association: Upper MidWest |
Hi Folks,
I was able to take my new to me 914 for a short drive yesterday. The car is a 74 with what I think is the original 2.0. It has Dual weber 40's and what I think is the stock distributor. The cap and rotor look practically new and the plug wire in good condition. It wouldn't start a few weeks ago and I pulled the plugs (NGK 7) and cleaned them, fired right up after that (Never had webers before and I think I flooded the cycling a little pumping the gas pedal thinking it would help start. Other observations. The few times I have started it (usually after sitting over a week) I crank the engine, and give a dab of the gas pedal to get it to fire, usually takes several tries to get. running. After warming up a bit engine goes through revs well. On the drive the engine runs very rough usually between 2-3k its barely pulling. Lots of hesitation and at odd times it pops to live a pulls great. My first thought is to pull the carbs, do a thorough cleaning and check to see what jets are fitted and the condition of the floats. Also planned are a timing check, valve adjust, oil and filter, fuel filter. Is there any other details I can provide for suggestions on how to get things running well? (IMG:style_emoticons/default/poke.gif) Thank you! Steve Attached thumbnail(s) |
Superhawk996 |
Feb 24 2023, 08:36 PM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Love the garage wall - like the repurposed / barn lumber look
Car not to shabby either (IMG:style_emoticons/default/aktion035.gif) Wile you have it all apart - note the size of all your jets and the Venturi’s - you’ll need to know these if carb needs tuning later. You may have to take the venturis out of the carb body to see marked size. |
skota23 |
Feb 26 2023, 06:11 PM
Love the garage wall - like the repurposed / barn lumber look Car not to shabby either (IMG:style_emoticons/default/aktion035.gif) Wile you have it all apart - note the size of all your jets and the Venturi’s - you’ll need to know these if carb needs tuning later. You may have to take the venturis out of the carb body to see marked size. Thanks Superhawk996! Noted on the jet sizes. I’ll do that! I can see 28 on the Venturi’s |
Lo-Fi Version | Time is now: 10th June 2024 - 02:08 AM |
