> New-to-Me 74 1.8l_Where to start on electrical issues
rcautox
post Feb 20 2023, 06:47 PM
Hi all,
I've been scouring 914 world for help on getting a new-to-me '74 1.8l running. I've reviewed Auto Atlanta's informative video on the 914 fuse & wiring and I think I follow the gist but may have missed things. I've also studied the simplified diagrams on Pelican Parts which have been helpful to understand the 914 layout.
What I've done:
1. new battery
2. new ground strap straight to the transmission bolt in the rear of the engine bay
3. cleaned battery connections
4. cleaned the fuse panel
When I turn the key the only thing I can see working is the marker lights and the clock. So no fuel pump, no start, etc.
Can you all point me to a few areas to tackle first to determine the culprit(s)?
Van B
post Feb 26 2023, 08:10 PM
Yeah don’t forget they are plugged like that because they both used to plug into the relay. So if you disconnect them you’re not gonna have power at all
rcautox   New-to-Me 74 1.8l_Where to start on electrical issues   Feb 20 2023, 06:47 PM
SteveL   Seat Belt Interlock ?   Feb 20 2023, 06:49 PM
Van B   Carbs, FI?   Feb 20 2023, 08:14 PM
Dave_Darling   Start at the wiring diagrams. Your Haynes manual ...   Feb 21 2023, 03:32 AM
930cabman   :wttc: Was the car running when you purchased he...   Feb 21 2023, 07:15 AM
rcautox   Regarding seat belt bypass-I pull the passenger se...   Feb 21 2023, 11:25 AM
bdstone914   Regarding seat belt bypass-I pull the passenger s...   Feb 21 2023, 12:45 PM
wonkipop   Regarding seat belt bypass-I pull the passenger s...   Feb 21 2023, 01:47 PM
Van B   So, two things to check: 1.) With the key on, pus...   Feb 21 2023, 12:29 PM
rcautox   Thank you for the detailed suggestions. I gently p...   Feb 21 2023, 11:50 PM
wonkipop   Thank you for the detailed suggestions. I gently ...   Feb 22 2023, 04:46 PM
Van B   Thank you for the detailed suggestions. I gently ...   Feb 22 2023, 08:37 PM
StarBear   On 1.8s, don’t forget the unique dual relay and ...   Feb 22 2023, 08:11 AM
rcautox   Fuel pump is in the front. I pulled the tank, clea...   Feb 22 2023, 10:56 PM
wonkipop   Fuel pump is in the front. I pulled the tank, cle...   Feb 23 2023, 02:10 PM
Dave_Darling   The yellow wire should be getting power only while...   Feb 23 2023, 12:53 AM
rcautox   In the starting position I do not have power in th...   Feb 25 2023, 02:53 PM
porschetub   In the starting position I do not have power in t...   Feb 26 2023, 01:19 PM
Dave_Darling   In the starting position I do not have power in t...   Feb 26 2023, 05:10 PM
r_towle   You have power, key in start position, to the yell...   Feb 26 2023, 05:30 PM
rcautox   I removed the male spade connector and tested each...   Feb 26 2023, 07:59 PM
Van B   Yeah don’t forget they are plugged like that bec...   Feb 26 2023, 08:10 PM
Dave_Darling   The whole idea is that the yellow wire carries the...   Feb 26 2023, 09:25 PM
rcautox   Thank you for the help! I have power at pin 1 ...   Feb 28 2023, 12:44 PM
Dave_Darling   Sounds like either a bad connection there, or mayb...   Mar 1 2023, 08:38 PM
rcautox   I pulled the cover off the 12 pit connector, gentl...   Mar 3 2023, 01:06 PM
- Lo-Fi Version Time is now: 18th August 2025 - 03:45 PM
