| Montreal914 |
Mar 1 2023, 10:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,092 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
The Bilstein rear shock has a ring to adjust the height in steps.
![]() Pictures from PMB website In order to increase the accuracy of the adjustment one would have to install those threaded adjusters which are sold as coil over shock kits (even though the 914 rear suspension is coil over shock by design but that is a different discussion...). The question is this one: Is there a threaded adjustable setup that can be used with my set of Weltmeister 140lbs progressive springs which fit in the standard perch (to my knowledge)? Seems to me all that would be needed is a perch that could fit on that adjustable nut, or am I missing something? (IMG:style_emoticons/default/confused24.gif) |
| Superhawk996 |
Mar 2 2023, 05:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,825 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I don’t understand the question.
There are currently three options. 1) Stock fixed perch. Least expensive. Satisfactory for at least 80% of the 914 market. Good 2) Bilstein adjustable perch with finite adjustment. Better 3) “Coil Over” with infinite adjustment and spring diameter sized to typical aftermarket race springs. Good for competition, unusual street applications not easily addressed via #1 or #2, or for those with an abundance of money that just want to look cool at Cars & Coffee. Best Why would a vendor tool up to make a 4th option that is a tweener between #2 and #3 for a tiny market segment? While it is possible to make a fully adjustable “coil over” that utilizes stock spring diameter, the question is why bother? Yes, you could make a perch to fit Weltmeister springs to the option #3 parts currently in the market. But keep this in mind, the perch will have to be thicker to resist the bending / deflection that will be generated by having the spring seat outer diameter further from the damper center line. You may run into issues with spring length or coil bind due to the physical differences between stock or Weltmeister springs and springs the “coil overs” were designed for. |
Montreal914 Adjustable rear suspension Mar 1 2023, 10:47 PM
Dave_Darling The short answer: No.
The long answer: The spri... Mar 2 2023, 02:51 AM
Geezer914 I went to my local salvage yard and found pipe col... Mar 2 2023, 06:41 AM
Montreal914
I went to my local salvage yard and found pipe co... Mar 2 2023, 09:11 AM
TargaToy
I went to my local salvage yard and found pipe co... Mar 2 2023, 07:33 PM
Superhawk996 Interesting solution.
It looks like the stock s... Mar 2 2023, 06:48 AM
Geezer914 Thank you. That is what this forum is about, shar... Mar 2 2023, 10:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:44 AM |
