| Montreal914 |
Mar 1 2023, 10:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,092 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
The Bilstein rear shock has a ring to adjust the height in steps.
![]() Pictures from PMB website In order to increase the accuracy of the adjustment one would have to install those threaded adjusters which are sold as coil over shock kits (even though the 914 rear suspension is coil over shock by design but that is a different discussion...). The question is this one: Is there a threaded adjustable setup that can be used with my set of Weltmeister 140lbs progressive springs which fit in the standard perch (to my knowledge)? Seems to me all that would be needed is a perch that could fit on that adjustable nut, or am I missing something? (IMG:style_emoticons/default/confused24.gif) |
| Geezer914 |
Mar 2 2023, 06:41 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,288 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I went to my local salvage yard and found pipe collars to fit over the the threaded part of the adjusters. I had to hog out the threads to make them fit and cut them to 1". The collar fits on top of the adjustment ring and the spring perch sits on top of the collar.
| TargaToy |
Mar 2 2023, 07:33 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
I went to my local salvage yard and found pipe collars to fit over the the threaded part of the adjusters. I had to hog out the threads to make them fit and cut them to 1". The collar fits on top of the adjustment ring and the spring perch sits on top of the collar. Geezer, did you already have a Ground Control or similar system on the rear? The gold anodized collar looks like their component. I’m unclear how you incorporated that with the salvage parts. Can you elaborate just a little more? Thanks! |
Montreal914 Adjustable rear suspension Mar 1 2023, 10:47 PM
Dave_Darling The short answer: No.
The long answer: The spri... Mar 2 2023, 02:51 AM
Superhawk996 I don’t understand the question.
There are cu... Mar 2 2023, 05:22 AM
Montreal914
I went to my local salvage yard and found pipe co... Mar 2 2023, 09:11 AM
Superhawk996 Interesting solution.
It looks like the stock s... Mar 2 2023, 06:48 AM
Geezer914 Thank you. That is what this forum is about, shar... Mar 2 2023, 10:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:45 AM |
