> Mega Squirt advice, tips, discussion...
balthazar
post Jan 19 2005, 08:42 PM
P-car junkie
Hi all,
I have pulled the drivetrain out in order to rebuild the transaxle. That job will be done this weekend! YAY! I am stoked! I will go from having 2nd,3rd and 5th gears (no reverse) to a newly built transaxle! I can't wait! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
But that's not what I wanted to talk about. I had 40idf carbs installed on my 1.7 previously. This was a marginal set-up at best. I have now removed them and I am planning on installing FI. I will be going with the MS computer, mallory dist. and a 30kv coil along with stock T-body, injecters, plenum, and intake runners. If possible, I will use the stock D-Jet sensors as well.
I have a degree in electronics engineering, and have been working in the field for 10yrs now, so I know my way around a soldering iron. That being said, I plan to build the kit myself. I have read through several sites describing the theory behind the MS set-up and even found a site describing the installation on a sand rail. All of this info was very informative, and has given me the confidence to go ahead with the project asap.
Most of the info out there is pretty general when it comes to actual applications. I have yet to find a description of a T4/914 specific install. I know a few of you out there have already done this thing.
My question: Are there any T4/914 specific tips, tricks, methods and etc...that anyone could bestow upon my humbleness? I would be MOST appreciative!!!!
balthazar   Mega Squirt advice, tips, discussion...   Jan 19 2005, 08:42 PM
Mueller   I had an 1.8 running the 1st version of MS a few y...   Jan 19 2005, 08:54 PM
Brett W   I want to here this as well. I will be getting tw...   Jan 20 2005, 12:55 AM
lapuwali   There isn't really a dedicated "spark unit". ...   Jan 20 2005, 02:40 AM
DNHunt   I've run MS for quite a while now and am worki...   Jan 20 2005, 08:18 AM
Mark Henry   Also check out sdsefi.com It's not megasquir...   Jan 20 2005, 08:55 AM
balthazar   Cool! Thanks guys, this helps alot! Dave:...   Jan 20 2005, 10:00 PM
Mueller     Jan 21 2005, 01:00 AM
balthazar   Wow! So when I finally get this thing back tog...   Jan 21 2005, 02:22 AM
Dr Evil   I am currently attempting to attach a Mega Jolt Li...   Jan 21 2005, 02:28 AM
crash914   Hello!!!! I have had mine for ove...   Jan 21 2005, 06:24 AM
balthazar   Those throttle bodies look nice! You are using...   Jan 28 2005, 02:48 PM
crash914   I am using the TPS. Now I am using the CHT for ...   Jan 28 2005, 04:19 PM
greg.treadway   What ignition system are you using with the Megasq...   Jan 28 2005, 05:15 PM
Mueller   http:...   Feb 1 2005, 08:34 PM
crash914   Where does that red tail light thingy go?? do I n...   Feb 2 2005, 04:33 AM
balthazar   You don't need it...One side is the decelerato...   Feb 2 2005, 11:29 AM
balthazar   Here is the stuff all assembled. I just found out ...   Feb 4 2005, 07:37 PM
balthazar   Man am I http://www.914world...   Feb 20 2005, 07:03 PM
balthazar   Another:   Feb 20 2005, 07:03 PM
balthazar   Finally an update on the project! http://www.914...   Oct 16 2005, 07:07 PM
qa1142   congratulations   Oct 16 2005, 08:06 PM
balthazar   Cool! Congrats, There is no better feeling tha...   Oct 16 2005, 11:48 PM
balthazar   LOL! i thought I would have it done by spring...   Dec 6 2006, 11:42 AM
balthazar   Here are some pix of my new toy...   Dec 6 2006, 09:03 PM
balthazar   Now for the 914 content... Here is a pic of the l...   Dec 6 2006, 09:20 PM
balthazar   ...   Dec 6 2006, 09:22 PM
- Lo-Fi Version Time is now: 10th June 2024 - 11:26 PM
