> Front Brake Issue, 914 Pulls right when stopping
PDXBob
post Mar 4 2023, 07:14 PM
Hi All,
I just finished putting on rebuilt rear brake calipers done by PMB. Also, new braided steel brake lines and set of new Textar pads on all 4 wheels (1975 914). I took it out to do the “bedding” break-in process and I noticed it was pulling to the right.
So, (after doing cool down slow driving)when I got home I checked temperature of rotors. Both back rotors were about 125 degrees. However front right was about 240 degrees. BUT front left was only about 85 degrees. To a novice like me seems like front left is not working.
Any suggestions on diagnostic procedures or what to check out.
Thanks
PDXBob
Krieger
post Mar 4 2023, 11:36 PM
Recheck the venting clearance again on your rear calipers. Follow the proper proceedure and set at .004"
PDXBob   Front Brake Issue   Mar 4 2023, 07:14 PM
bkrantz   I would jack up the front and have an assistant gr...   Mar 4 2023, 09:20 PM
ndfrigi   When you bled the left front, does it push brake f...   Mar 4 2023, 09:22 PM
PDXBob   Good suggestions about bleeding again and spinning...   Mar 4 2023, 11:15 PM
Krieger   Recheck the venting clearance again on your rear c...   Mar 4 2023, 11:36 PM
PatMc   Make sure you're bleeding from the uppermost b...   Mar 6 2023, 07:50 AM
Eric_Shea   Hey Bob, Are the soft lines new? If not then I w...   Mar 6 2023, 09:15 AM
PDXBob   Hey Bob, Are the soft lines new? If not then I ...   Mar 7 2023, 04:40 PM
Eric_Shea   [quote name='Eric_Shea' post='3062899' date='Mar ...   Mar 8 2023, 01:33 PM
technicalninja   Rear brakes are damn hard to get hot enough to ...   Mar 8 2023, 12:34 AM
Cairo94507   @Eric_Shea - Holly molly- 10 year unconditional w...   Mar 8 2023, 05:11 PM
Eric_Shea   Thank you Amigo!   Mar 8 2023, 06:57 PM
PDXBob   So, after performing several of the tests listed a...   Mar 22 2023, 03:28 PM
930cabman   So, after performing several of the tests listed ...   Mar 23 2023, 05:53 AM
PDXBob   So, an update: Had my front calipers just rebuilt ...   Apr 4 2023, 09:36 PM
rjames   So, an update: Had my front calipers just rebuilt...   Apr 5 2023, 05:00 AM
PDXBob   [quote name='PDXBob' post='3069725' date='Apr 4 2...   Apr 5 2023, 02:08 PM
technicalninja   The rear adjustment can be difficult to gauge. Jus...   Apr 4 2023, 09:49 PM
emerygt350   The rear adjustment can be difficult to gauge. Ju...   Apr 6 2023, 04:21 PM
Olympic 914   Just ran through this myself. Adjusted rear brak...   Apr 5 2023, 07:02 AM
Superhawk996   Raise the rear of the car to help move air through...   Apr 5 2023, 07:31 AM
brubou   I would start at the beginning of the system. Thro...   Apr 5 2023, 10:03 AM
rhodyguy   Long hose=speed bleeders in the top caliper bleede...   Apr 5 2023, 02:27 PM
PDXBob   Long hose=speed bleeders in the top caliper bleed...   Apr 5 2023, 04:01 PM
brubou   Correct, there is a one way valve mechanism in the...   Apr 5 2023, 04:14 PM
rjames   When I had my brakes refurbished they came with re...   Apr 5 2023, 04:23 PM
rhodyguy   You will see the bubbles traveling thru the tube w...   Apr 5 2023, 04:25 PM
76-914   I run the hose all the way to the reservoir. That ...   Apr 5 2023, 05:51 PM
rhodyguy   Return to reservoir….I’m going to get new long...   Apr 5 2023, 05:57 PM
emerygt350   Interesting. How do you seal the line at the blee...   Apr 5 2023, 06:31 PM
rhodyguy   You get tubing that’s a snug fit. The fluid is n...   Apr 5 2023, 08:11 PM
emerygt350   I figured if you are running it all the way back i...   Apr 6 2023, 06:09 AM
rjames   I figured if you are running it all the way back ...   Apr 6 2023, 12:51 PM
PDXBob   I’m going to try the long hose bleeding method s...   Apr 6 2023, 06:17 PM
emerygt350   I am not there yet. I have been bleeding crappy o...   Apr 6 2023, 07:08 PM
- Lo-Fi Version Time is now: 7th July 2026 - 04:52 PM
