> Case question for possible location for crank trigger
technicalninja
post Mar 4 2023, 02:45 PM
What was the original use for the large hole on the flywheel side of the right (passenger) engine case?
Looks like it could have been a good flywheel lock location.
To me it looks like very good spot for a crankshaft position sensor...
What was its original reason for being there?
technicalninja
post Mar 5 2023, 10:32 AM
Wow, you did it the HARD way...
20 years ago, there was limited stand-alone equipment and I understand why you did it that way.
How many slots did you have to cut into that flywheel?
What a PIA!
I'm planning to use the holes for the clutch bolts (they are symmetrical at 60 degrees) to trigger a MS3x. The stock flywheel might give me trouble (because of the extra balancing holes) but an aftermarket conversion flywheel appears to have only the holes for the clutch plate. The MS3 can trigger on either the leading or trailing signal from the sensor and you can apply any offset you desire.
The distributor can be turned into a cam sensor and I have both sensors figured out now.
I'm buying one of the unilights in the for-sale forum as it should be gravy to make into a cam sensor set up.
I DO need to come visit you.
I wish "Vulcan Mind Meld" was a real thing...
technicalninja   Case question for possible location for crank trigger   Mar 4 2023, 02:45 PM
ClayPerrine   What was the original use for the large hole on t...   Mar 4 2023, 08:03 PM
technicalninja   Wow, you did it the HARD way... 20 years ago, the...   Mar 5 2023, 10:32 AM
ClayPerrine   Wow, you did it the HARD way... 20 years ago, th...   Mar 5 2023, 07:27 PM
ogdougy   Just to be the devils advocate. Why not just get a...   Mar 5 2023, 11:31 AM
GregAmy   https://thedubshop.com/crank-trigger-package-type-...   Mar 5 2023, 11:56 AM
technicalninja   Thanks for other options guys. The set up I have ...   Mar 5 2023, 01:05 PM
technicalninja   One of the real early uses of coil on plug! W...   Mar 6 2023, 08:49 AM
nditiz1   I'm not sure if Original Customs still makes t...   Mar 6 2023, 09:00 AM
Eric_Shea   We use the DubShop units if the engine is out. We...   Mar 6 2023, 09:26 AM
technicalninja   Eric, thanks for the tips! My first ideas for...   Mar 6 2023, 10:45 AM
ogdougy   Most of the OEMs have moved to directly on whate...   Mar 6 2023, 12:24 PM
Eric_Shea   Way too much thinking for a T4 ;)   Mar 6 2023, 12:46 PM
r_towle   once you put the motor together, the cam timing an...   Mar 6 2023, 12:52 PM
technicalninja   I think you are over estimating the "jitter...   Mar 6 2023, 12:52 PM
technicalninja   Way too much thinking for a T4 ;) I slowly com...   Mar 6 2023, 01:00 PM
r_towle   I have a few questions. I get the install of the c...   Mar 6 2023, 01:06 PM
ClayPerrine   Zims is building a drop in EFI kit for the 914. I...   Mar 6 2023, 02:44 PM
nditiz1   SOT: As someone that has done a 6 conversion...I w...   Mar 6 2023, 03:25 PM
technicalninja   Zims is building a drop in EFI kit for the 914. ...   Mar 6 2023, 09:08 PM
ClayPerrine   Zims is building a drop in EFI kit for the 914. ...   Mar 7 2023, 06:30 AM
technicalninja   Yep, actually I'll use a GM flex fuel sensor a...   Mar 7 2023, 02:52 PM
ClayPerrine   Yep, actually I'll use a GM flex fuel sensor ...   Mar 7 2023, 03:21 PM
technicalninja   My first 914 was a rusted out 70 1.7 with a 1911??...   Mar 7 2023, 04:09 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:29 PM
