| gulf908 |
Feb 21 2023, 12:33 AM
Member ![]() ![]() Group: Members Posts: 130 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
guys
I have been recently having trouble with my speedo needle its OK from cold but as the car warms up esp on a warm day,the needle has a bad case of the St Vitus dance between zero kph and about 50 kph and starts doing 270s after that at a steady 50 kph upwards,its quite stable the speedo has about 24k kms from a NHS rebuild about 8 1/2 years ago my mechanic has looked at it and can't see anything obviously wrong with the cable and seems to think its a design fault somewhere does this sound like the cable or the gauge ? its becoming a bit alarming to see the needle flicker too much over to the experts TIA Dennis (IMG:style_emoticons/default/biggrin.gif) |
| 914sgofast2 |
Mar 5 2023, 09:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 782 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Has anybody ever found a solution to this jitterbug speedo needle issue? My car had a new speedo cable, but it didn’t fix the jitters.
gulf908 Jitterbug speedo Feb 21 2023, 12:33 AM
Dave_Darling I think the cable is a more likely suspect than th... Feb 21 2023, 03:24 AM
FlacaProductions When this happened to me, it eventually started sq... Feb 21 2023, 10:59 AM
FlacaProductions double post Feb 21 2023, 10:59 AM
914sgofast2 My speedometer did the same thing. It was the cabl... Feb 21 2023, 11:48 AM
gulf908 thanks All
I have a minor service due soon and I ... Feb 24 2023, 11:32 PM
r_towle I did not know there was anything like “minor se... Feb 25 2023, 12:32 PM
ClayPerrine I would agree that it is the speedo cable. They ar... Feb 26 2023, 09:48 AM
Dave_Darling Check the cable routing. If it is bent too tightl... Mar 6 2023, 04:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 04:07 PM |
