> Case question for possible location for crank trigger
technicalninja
post Mar 4 2023, 02:45 PM
What was the original use for the large hole on the flywheel side of the right (passenger) engine case?
Looks like it could have been a good flywheel lock location.
To me it looks like very good spot for a crankshaft position sensor...
What was its original reason for being there?
Eric_Shea
post Mar 6 2023, 12:46 PM
PMB Performance
Way too much thinking for a T4 (IMG:style_emoticons/default/wink.gif)
technicalninja   Case question for possible location for crank trigger   Mar 4 2023, 02:45 PM
ClayPerrine   What was the original use for the large hole on t...   Mar 4 2023, 08:03 PM
technicalninja   Wow, you did it the HARD way... 20 years ago, the...   Mar 5 2023, 10:32 AM
ClayPerrine   Wow, you did it the HARD way... 20 years ago, th...   Mar 5 2023, 07:27 PM
ogdougy   Just to be the devils advocate. Why not just get a...   Mar 5 2023, 11:31 AM
GregAmy   https://thedubshop.com/crank-trigger-package-type-...   Mar 5 2023, 11:56 AM
technicalninja   Thanks for other options guys. The set up I have ...   Mar 5 2023, 01:05 PM
technicalninja   One of the real early uses of coil on plug! W...   Mar 6 2023, 08:49 AM
nditiz1   I'm not sure if Original Customs still makes t...   Mar 6 2023, 09:00 AM
Eric_Shea   We use the DubShop units if the engine is out. We...   Mar 6 2023, 09:26 AM
technicalninja   Eric, thanks for the tips! My first ideas for...   Mar 6 2023, 10:45 AM
ogdougy   Most of the OEMs have moved to directly on whate...   Mar 6 2023, 12:24 PM
Eric_Shea   Way too much thinking for a T4 ;)   Mar 6 2023, 12:46 PM
r_towle   once you put the motor together, the cam timing an...   Mar 6 2023, 12:52 PM
technicalninja   I think you are over estimating the "jitter...   Mar 6 2023, 12:52 PM
technicalninja   Way too much thinking for a T4 ;) I slowly com...   Mar 6 2023, 01:00 PM
r_towle   I have a few questions. I get the install of the c...   Mar 6 2023, 01:06 PM
ClayPerrine   Zims is building a drop in EFI kit for the 914. I...   Mar 6 2023, 02:44 PM
nditiz1   SOT: As someone that has done a 6 conversion...I w...   Mar 6 2023, 03:25 PM
technicalninja   Zims is building a drop in EFI kit for the 914. ...   Mar 6 2023, 09:08 PM
ClayPerrine   Zims is building a drop in EFI kit for the 914. ...   Mar 7 2023, 06:30 AM
technicalninja   Yep, actually I'll use a GM flex fuel sensor a...   Mar 7 2023, 02:52 PM
ClayPerrine   Yep, actually I'll use a GM flex fuel sensor ...   Mar 7 2023, 03:21 PM
technicalninja   My first 914 was a rusted out 70 1.7 with a 1911??...   Mar 7 2023, 04:09 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:24 PM
