technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
What was the original use for the large hole on the flywheel side of the right (passenger) engine case?
Looks like it could have been a good flywheel lock location. To me it looks like very good spot for a crankshaft position sensor... What was its original reason for being there? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,491 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Zims is building a drop in EFI kit for the 914. It is running on the first motor.
Took it from about 85 wheel horsepower to 120 wheel horsepower with no internal engine mods. And it looks like a pair of downdraft carbs. Even uses the same throttle linkage. And no chassis mods. Installation would be about 4 hours if you already have stock fuel injection. Even the basic fuel map will be ready to run. It is all plug and play. But for best performance, you need to get it dyno tuned for your engine after installation. @partsguy22 - Got pictures? |
Lo-Fi Version | Time is now: 1st August 2025 - 12:24 PM |
