> Stereo Install Wiring Help, 74 914 2.0
OKN929
post Mar 5 2023, 10:50 PM
Hello 914 World! I'm a new owner of a 914 that long overdue. Got so much great info from here and been working on it slowly and it's been amazing all that 914World members help each other!
Now I got my dash restored and the gauges all looking nice and new with a few upgrades and need help with installing a stereo.
My 914 has an antenna but no stereo wires, can someone please tell me which wires I would need to tap into to get my stereo installed correctly.
Thank all in advance!!!
914Sixer
post Mar 6 2023, 07:13 AM
Installation is going to be dependent on what your using. Most just require a 12v and a ground. Ground can be pulled from just about anywhere. Hot wire can be run from fuse block. Check vacant spades to see what is switched 12v by using ignition switch.
OKN929
post Mar 7 2023, 12:05 PM
QUOTE(914Sixer @ Mar 6 2023, 08:13 AM) *
Thank you for the tip. It should be easy to find a 12v and ground, I also have the yellow wire which I believe is to shut off when the car turns off so the stereo doesn't stay on.
OKN929   Stereo Install Wiring Help   Mar 5 2023, 10:50 PM
914Sixer   Installation is going to be dependent on what your...   Mar 6 2023, 07:13 AM
OKN929   Installation is going to be dependent on what you...   Mar 7 2023, 12:05 PM
Superhawk996   :wttc:   Mar 6 2023, 09:28 AM
NARP74   Welcome, a couple of really long detailed threads ...   Mar 6 2023, 09:34 AM
OKN929   Welcome, a couple of really long detailed threads...   Mar 7 2023, 12:06 PM
rhodyguy   Don’t run a long screw through the firewall, cha...   Mar 6 2023, 09:37 AM
r_towle   Don’t run a long screw through the firewall, ch...   Mar 7 2023, 02:15 PM
OKN929   Don’t run a long screw through the firewall, c...   Mar 7 2023, 04:01 PM
Jonathan Livesay   Don’t run a long screw through the firewall, c...   Mar 10 2023, 01:24 PM
FlacaProductions   These might get you started... http://www.914worl...   Mar 6 2023, 11:05 AM
OKN929   These might get you started... http://www.914wor...   Mar 7 2023, 12:07 PM
technicalninja   Those two threads are for serious amplified system...   Mar 7 2023, 11:40 PM
TROJANMAN   The best stereo I ever bought were Webers   Mar 9 2023, 09:10 AM
NARP74   The best stereo I ever bought were Webers PLUS 1...   Mar 9 2023, 09:31 AM
OKN929   The best stereo I ever bought were Webers Been ...   Mar 9 2023, 01:43 PM
Superhawk996   The best stereo I ever bought were Webers :firs...   Mar 9 2023, 01:53 PM
CCE   The best stereo I ever bought were Webers :fir...   Mar 10 2023, 12:38 AM
OKN929   The best stereo I ever bought were Webers Ok.......   Mar 10 2023, 01:21 PM
FlacaProductions   I get the "motor-sounds-as-music" viewpo...   Mar 10 2023, 09:46 AM
Osnabruck914   While you're at it, installing a power antenna...   Mar 10 2023, 01:12 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 11:50 AM
