| PDXBob |
Mar 4 2023, 07:14 PM
Member ![]() ![]() Group: Members Posts: 63 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest
Hi All,
I just finished putting on rebuilt rear brake calipers done by PMB. Also, new braided steel brake lines and set of new Textar pads on all 4 wheels (1975 914). I took it out to do the “bedding” break-in process and I noticed it was pulling to the right. So, (after doing cool down slow driving)when I got home I checked temperature of rotors. Both back rotors were about 125 degrees. However front right was about 240 degrees. BUT front left was only about 85 degrees. To a novice like me seems like front left is not working. Any suggestions on diagnostic procedures or what to check out. Thanks PDXBob |
| Eric_Shea |
Mar 6 2023, 09:15 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hey Bob,
Are the soft lines new? If not then I would recommend checking those. https://pmbperformance.com/pages/frequently...-questions-faqs About mid-way down on our FAQ page you'll see that old soft lines lines can swell from the inside. This often retains pressure on your front right (in your case). It will then lock up and pull to the right when you apply nominal pressure. It often drags as well then causing the heating issue you're having. My rule is, if you don't know when your soft lines were replaced... replace them. Otherwise, every 10 years. Hope that helps... give us a call if you have any other issues. |
| PDXBob |
Mar 7 2023, 04:40 PM
Hey Bob, Are the soft lines new? If not then I would recommend checking those. https://pmbperformance.com/pages/frequently...-questions-faqs About mid-way down on our FAQ page you'll see that old soft lines lines can swell from the inside. This often retains pressure on your front right (in your case). It will then lock up and pull to the right when you apply nominal pressure. It often drags as well then causing the heating issue you're having. My rule is, if you don't know when your soft lines were replaced... replace them. Otherwise, every 10 years. Hope that helps... give us a call if you have any other issues. Eric, when I had you rebuild the rear calipers I also bought a set of your braided steel brake lines. These were well worth the price, just in piece of mind compared to 40+ year old rubber lines. No time to work on it until Saturday, but can’t wait to get brakes sorted. Also, my brother who’s a mechanic chastised me for not getting rotors hot enough during “bedding-in” process. It’s tough to drive 60 MPH and slam on the brakes in Oregon when the roads are wet 364 days a year!!! Bob |
| Eric_Shea |
Mar 8 2023, 01:33 PM
Hey Bob, Are the soft lines new? If not then I would recommend checking those. https://pmbperformance.com/pages/frequently...-questions-faqs About mid-way down on our FAQ page you'll see that old soft lines lines can swell from the inside. This often retains pressure on your front right (in your case). It will then lock up and pull to the right when you apply nominal pressure. It often drags as well then causing the heating issue you're having. My rule is, if you don't know when your soft lines were replaced... replace them. Otherwise, every 10 years. Hope that helps... give us a call if you have any other issues. Eric, when I had you rebuild the rear calipers I also bought a set of your braided steel brake lines. These were well worth the price, just in piece of mind compared to 40+ year old rubber lines. No time to work on it until Saturday, but can’t wait to get brakes sorted. Also, my brother who’s a mechanic chastised me for not getting rotors hot enough during “bedding-in” process. It’s tough to drive 60 MPH and slam on the brakes in Oregon when the roads are wet 364 days a year!!! Bob Let me know if you have any caliper issues. You have a 10-Year Unconditional warranty. (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/beerchug.gif) |
PDXBob Front Brake Issue Mar 4 2023, 07:14 PM
bkrantz I would jack up the front and have an assistant gr... Mar 4 2023, 09:20 PM
ndfrigi When you bled the left front, does it push brake f... Mar 4 2023, 09:22 PM
PDXBob Good suggestions about bleeding again and spinning... Mar 4 2023, 11:15 PM
Krieger Recheck the venting clearance again on your rear c... Mar 4 2023, 11:36 PM
PatMc Make sure you're bleeding from the uppermost b... Mar 6 2023, 07:50 AM
technicalninja Rear brakes are damn hard to get hot enough to ... Mar 8 2023, 12:34 AM
Cairo94507 @Eric_Shea - Holly molly- 10 year unconditional w... Mar 8 2023, 05:11 PM
Eric_Shea Thank you Amigo! Mar 8 2023, 06:57 PM
PDXBob So, after performing several of the tests listed a... Mar 22 2023, 03:28 PM
930cabman
So, after performing several of the tests listed ... Mar 23 2023, 05:53 AM
PDXBob So, an update:
Had my front calipers just rebuilt ... Apr 4 2023, 09:36 PM
rjames
So, an update:
Had my front calipers just rebuilt... Apr 5 2023, 05:00 AM
PDXBob
[quote name='PDXBob' post='3069725' date='Apr 4 2... Apr 5 2023, 02:08 PM
technicalninja The rear adjustment can be difficult to gauge.
Jus... Apr 4 2023, 09:49 PM
emerygt350
Ju... Apr 6 2023, 04:21 PM
Olympic 914 Just ran through this myself.
Adjusted rear brak... Apr 5 2023, 07:02 AM
Superhawk996 Raise the rear of the car to help move air through... Apr 5 2023, 07:31 AM
brubou I would start at the beginning of the system. Thro... Apr 5 2023, 10:03 AM
rhodyguy Long hose=speed bleeders in the top caliper bleede... Apr 5 2023, 02:27 PM
PDXBob
Long hose=speed bleeders in the top caliper bleed... Apr 5 2023, 04:01 PM
brubou Correct, there is a one way valve mechanism in the... Apr 5 2023, 04:14 PM
rjames When I had my brakes refurbished they came with re... Apr 5 2023, 04:23 PM
rhodyguy You will see the bubbles traveling thru the tube w... Apr 5 2023, 04:25 PM
76-914 I run the hose all the way to the reservoir. That ... Apr 5 2023, 05:51 PM
rhodyguy Return to reservoir….I’m going to get new long... Apr 5 2023, 05:57 PM
emerygt350 Interesting. How do you seal the line at the blee... Apr 5 2023, 06:31 PM
rhodyguy You get tubing that’s a snug fit. The fluid is n... Apr 5 2023, 08:11 PM
emerygt350 I figured if you are running it all the way back i... Apr 6 2023, 06:09 AM
rjames
I figured if you are running it all the way back ... Apr 6 2023, 12:51 PM
PDXBob I’m going to try the long hose bleeding method s... Apr 6 2023, 06:17 PM
emerygt350 I am not there yet. I have been bleeding crappy o... Apr 6 2023, 07:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th July 2026 - 04:53 PM |
