| 930cabman |
Mar 10 2023, 04:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,637 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Is an external oil cooler required for a /6 conversion? The Palma Green car needs a bit of work prior to the install, so we have a bit of time. Newly rebuilt 2.7 will be fit with Webers and driven on the street only.
TIA |
| mlindner |
Mar 11 2023, 09:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,764 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
I have a 2.2 with S piston and Mod-Solex cams. And only stock engine cooler. Never goes above 210 even when pounding on it to 7000 redline. My gauge is pretty close but I do check with a laser infrared gun on the oil filter, cam housing and lower case/oil drain plug. Never see 200 deg. Also check header temperature for each cylinder for any major variance. Best, Mark
930cabman /6 conversion Mar 10 2023, 04:45 PM
brant Some say not for 2.4 and smaller
But I have 3 oil ... Mar 10 2023, 05:08 PM
Root_Werks I don't have one on my 2.7, stock engine with ... Mar 10 2023, 05:11 PM
930cabman
I don't have one on my 2.7, stock engine with... Mar 10 2023, 05:24 PM
Root_Werks
I don't have one on my 2.7, stock engine wit... Mar 10 2023, 05:29 PM
flyer86d Our old 73 911T MFI car ran fine on the street but... Mar 10 2023, 05:39 PM
Steve When I had a 2.7 it over heated without an externa... Mar 10 2023, 07:29 PM
nditiz1 My 2.4t engine starts to get warm up to the 230s e... Mar 10 2023, 08:04 PM
targa72e I have had four engines in my -6 conversion. Two w... Mar 11 2023, 12:04 AM
TROJANMAN My 2.7 was running on the upper end of acceptable.... Mar 11 2023, 09:20 AM
I have a 2.2 with S piston and Mod-Solex cams. An... Mar 11 2023, 10:04 AM
930cabman
I have a 2.2 with S piston and Mod-Solex cams. A... Mar 11 2023, 06:29 PM
zoomCat
Some engines run cooler than others. Proper tunin... Mar 12 2023, 12:48 PM
Cairo94507 I have had a few different oil coolers in my Sixes... Mar 11 2023, 10:02 AM
Cairo94507 Yes, I believe it does as the engine fan moves air... Mar 12 2023, 01:12 PM
altitude411
Yes, I believe it does as the engine fan moves ai... Mar 12 2023, 01:29 PM
SirAndy Yes, I believe it does as the engine fan moves air... Mar 12 2023, 01:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 11:01 AM |
