914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I am replacing the calipers on my car. After pumping the old fluid out, we realized the soft lines needed repair (they were fine before). Now, there is a link under the car that appears to be coming from the master cylinder:
![]() The dark areas are wet with brake fluid. Here is a closeup of the master cylinder. The dark areas are wet. The only spot that is not wet (yet) is the lighter area on the lower left: ![]() I have checked the reservoir at the top and it is fine. The fluid is coming from somewhere down here. Please advise! Thanks! -Jeff ----------- |
Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 866 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
Just to double check things, if you have carpet, I'd pull it up and look under the pedals/pedal board area, and see if you have any brake fluid pooling in there. If not, I'd check the connections between the hard lines and MC in that area....make sure that they are tight.
Lo-Fi Version | Time is now: 7th September 2025 - 09:12 AM |
