> I think I have a leak near the master brake cylinder, is this bad, or fixable?
914 RZ-1
post Mar 11 2023, 10:58 AM
Porsche Padawan
I am replacing the calipers on my car. After pumping the old fluid out, we realized the soft lines needed repair (they were fine before). Now, there is a link under the car that appears to be coming from the master cylinder:
The dark areas are wet with brake fluid.
Here is a closeup of the master cylinder. The dark areas are wet. The only spot that is not wet (yet) is the lighter area on the lower left:
I have checked the reservoir at the top and it is fine. The fluid is coming from somewhere down here.
Please advise!
Thanks!
-Jeff
Craigers17
post Mar 11 2023, 11:52 AM
Based on that last picture, at a bare minimum, I don't think it would be a bad idea to pull out that pedal cluster, clean up that floorboard, remove all the surface rust and get some new paint and primer on it before you put everything back in. My guess is your MC is hosed.....I know everyone likes the 19mm, and I replaced mine with one a few years ago. But, personally, I liked the 17mm better.
914 RZ-1   I think I have a leak near the master brake cylinder   Mar 11 2023, 10:58 AM
Craigers17   Just to double check things, if you have carpet, I...   Mar 11 2023, 11:34 AM
914 RZ-1   Here's a view under the carpet. It's wet. ...   Mar 11 2023, 11:41 AM
brant   You need to pull the pedal board Then the rubber s...   Mar 11 2023, 11:42 AM
Craigers17   Based on that last picture, at a bare minimum, I d...   Mar 11 2023, 11:52 AM
Mikey914   1st, yank this out and clean up the fluid. I'd...   Mar 11 2023, 12:02 PM
914 RZ-1   1st, yank this out and clean up the fluid. I...   Mar 11 2023, 05:26 PM
930cabman   Time for a new Master Cylinder   Mar 11 2023, 02:45 PM
914 RZ-1   Yeah, I'm gonna clean this all up: pedal clust...   Mar 11 2023, 02:51 PM
bdstone914   Yeah, I'm gonna clean this all up: pedal clus...   Mar 11 2023, 03:38 PM
flyer86d   Replace the master cylinder. If your pedal cluster...   Mar 11 2023, 03:23 PM
troth   This was the result of a mc leak on my 911. I w...   Mar 11 2023, 03:26 PM
914 RZ-1   How do I get the lines on the top detached from th...   Mar 11 2023, 05:08 PM
Craigers17   You can just pull the steel parts of those reservo...   Mar 11 2023, 06:51 PM
914 RZ-1   You can just pull the steel parts of those reserv...   Mar 11 2023, 10:02 PM
Garland   Don’t forget the MC washers! “914 World ...   Mar 11 2023, 07:41 PM
76-914   A nickel to a donut your MC is toast. It will be m...   Mar 11 2023, 07:51 PM
914 RZ-1   I got it off. I just needed to pull it out a littl...   Mar 11 2023, 08:46 PM
bkrantz   What I like to do, for removing and installing the...   Mar 11 2023, 09:09 PM
914 RZ-1   What I like to do, for removing and installing th...   Mar 11 2023, 09:42 PM
Mikey914   Sorry was working in the shop today. Sounds like y...   Mar 11 2023, 09:52 PM
914 RZ-1   Which hoses from the reservoir go where? I've ...   Mar 11 2023, 09:59 PM
Mikey914   Which hoses from the reservoir go where? I've...   Mar 12 2023, 12:40 AM
- Lo-Fi Version Time is now: 7th September 2025 - 09:11 AM
