> I think I have a leak near the master brake cylinder, is this bad, or fixable?
914 RZ-1
post Mar 11 2023, 10:58 AM
Porsche Padawan
I am replacing the calipers on my car. After pumping the old fluid out, we realized the soft lines needed repair (they were fine before). Now, there is a link under the car that appears to be coming from the master cylinder:
The dark areas are wet with brake fluid.
Here is a closeup of the master cylinder. The dark areas are wet. The only spot that is not wet (yet) is the lighter area on the lower left:
I have checked the reservoir at the top and it is fine. The fluid is coming from somewhere down here.
Please advise!
Thanks!
-Jeff
Mikey914
post Mar 11 2023, 12:02 PM
The rubber man
1st, yank this out and clean up the fluid. I'd personally de-grease the metal and hit with POR15. I don;t think the MC is toast. The pattern of fluid indicates a leak from the top.
It could be a simple as the rubber intake lines aren't pushed in all the way.
Do check the lines coming down.
When the hoses fail (and many did as the hose MUST be hydraulic rated hose) as wrong ones that look the same get used, this is what it looks like. Other than the clean up, this might be easier than you think.
You mentioned the soft lines needed to be replaced, I suspect this is the issue. The material is significantly more expensive, but you don't need mch. I have both here for $12
-https://914rubber.com/new-brake-hose-9mm-set-of-2
Sorry no picture, I'll ask Blake to get it up.
-Mark
914 RZ-1
post Mar 11 2023, 05:26 PM
Porsche Padawan
QUOTE(Mikey914 @ Mar 11 2023, 10:02 AM) *
-Mark
@Mikey914 How do I get the hoses from the reservoir to the MC off? Is there some trick to disconnecting them at the ?MC?
And how would I install the new ones? Is installing them just a matter of fishing the new ones down?
It doesn't look like its those lines; the leak appears to be in the piston, but I may as well replace the reservoir lines as well.
Thanks!
-Jeff
914 RZ-1   I think I have a leak near the master brake cylinder   Mar 11 2023, 10:58 AM
Craigers17   Just to double check things, if you have carpet, I...   Mar 11 2023, 11:34 AM
914 RZ-1   Here's a view under the carpet. It's wet. ...   Mar 11 2023, 11:41 AM
brant   You need to pull the pedal board Then the rubber s...   Mar 11 2023, 11:42 AM
Craigers17   Based on that last picture, at a bare minimum, I d...   Mar 11 2023, 11:52 AM
Mikey914   1st, yank this out and clean up the fluid. I'd...   Mar 11 2023, 12:02 PM
914 RZ-1   1st, yank this out and clean up the fluid. I...   Mar 11 2023, 05:26 PM
930cabman   Time for a new Master Cylinder   Mar 11 2023, 02:45 PM
914 RZ-1   Yeah, I'm gonna clean this all up: pedal clust...   Mar 11 2023, 02:51 PM
bdstone914   Yeah, I'm gonna clean this all up: pedal clus...   Mar 11 2023, 03:38 PM
flyer86d   Replace the master cylinder. If your pedal cluster...   Mar 11 2023, 03:23 PM
troth   This was the result of a mc leak on my 911. I w...   Mar 11 2023, 03:26 PM
914 RZ-1   How do I get the lines on the top detached from th...   Mar 11 2023, 05:08 PM
Craigers17   You can just pull the steel parts of those reservo...   Mar 11 2023, 06:51 PM
914 RZ-1   You can just pull the steel parts of those reserv...   Mar 11 2023, 10:02 PM
Garland   Don’t forget the MC washers! “914 World ...   Mar 11 2023, 07:41 PM
76-914   A nickel to a donut your MC is toast. It will be m...   Mar 11 2023, 07:51 PM
914 RZ-1   I got it off. I just needed to pull it out a littl...   Mar 11 2023, 08:46 PM
bkrantz   What I like to do, for removing and installing the...   Mar 11 2023, 09:09 PM
914 RZ-1   What I like to do, for removing and installing th...   Mar 11 2023, 09:42 PM
Mikey914   Sorry was working in the shop today. Sounds like y...   Mar 11 2023, 09:52 PM
914 RZ-1   Which hoses from the reservoir go where? I've ...   Mar 11 2023, 09:59 PM
Mikey914   Which hoses from the reservoir go where? I've...   Mar 12 2023, 12:40 AM
- Lo-Fi Version Time is now: 7th September 2025 - 09:11 AM
