> /6 conversion, oil cooler
930cabman
post Mar 10 2023, 04:45 PM
Is an external oil cooler required for a /6 conversion? The Palma Green car needs a bit of work prior to the install, so we have a bit of time. Newly rebuilt 2.7 will be fit with Webers and driven on the street only.
TIA
mlindner
post Mar 11 2023, 09:33 AM
I have a 2.2 with S piston and Mod-Solex cams. And only stock engine cooler. Never goes above 210 even when pounding on it to 7000 redline. My gauge is pretty close but I do check with a laser infrared gun on the oil filter, cam housing and lower case/oil drain plug. Never see 200 deg. Also check header temperature for each cylinder for any major variance. Best, Mark
post Mar 11 2023, 10:04 AM
914-6 GT in waiting
QUOTE(mlindner @ Mar 11 2023, 10:33 AM) *
Some engines run cooler than others. Proper tuning helps. Driving at a good clip without going below 3k makes a big difference. It’s nice when it just works out. (IMG:style_emoticons/default/driving.gif)
930cabman
post Mar 11 2023, 06:29 PM
QUOTE(mepstein @ Mar 11 2023, 11:04 AM) *
Hopefully I can get this together this year to report back. Life just seems to take a priority most often.
930cabman   /6 conversion   Mar 10 2023, 04:45 PM
brant   Some say not for 2.4 and smaller But I have 3 oil ...   Mar 10 2023, 05:08 PM
Root_Werks   I don't have one on my 2.7, stock engine with ...   Mar 10 2023, 05:11 PM
930cabman   I don't have one on my 2.7, stock engine with...   Mar 10 2023, 05:24 PM
Root_Werks   I don't have one on my 2.7, stock engine wit...   Mar 10 2023, 05:29 PM
flyer86d   Our old 73 911T MFI car ran fine on the street but...   Mar 10 2023, 05:39 PM
Steve   When I had a 2.7 it over heated without an externa...   Mar 10 2023, 07:29 PM
nditiz1   My 2.4t engine starts to get warm up to the 230s e...   Mar 10 2023, 08:04 PM
targa72e   I have had four engines in my -6 conversion. Two w...   Mar 11 2023, 12:04 AM
TROJANMAN   My 2.7 was running on the upper end of acceptable....   Mar 11 2023, 09:20 AM
mlindner   I have a 2.2 with S piston and Mod-Solex cams. And...   Mar 11 2023, 09:33 AM
mepstein   I have a 2.2 with S piston and Mod-Solex cams. An...   Mar 11 2023, 10:04 AM
930cabman   I have a 2.2 with S piston and Mod-Solex cams. A...   Mar 11 2023, 06:29 PM
zoomCat   Some engines run cooler than others. Proper tunin...   Mar 12 2023, 12:48 PM
Cairo94507   I have had a few different oil coolers in my Sixes...   Mar 11 2023, 10:02 AM
Cairo94507   Yes, I believe it does as the engine fan moves air...   Mar 12 2023, 01:12 PM
altitude411   Yes, I believe it does as the engine fan moves ai...   Mar 12 2023, 01:29 PM
SirAndy   Yes, I believe it does as the engine fan moves air...   Mar 12 2023, 01:56 PM
- Lo-Fi Version Time is now: 29th April 2026 - 11:02 AM
