| bossboy302 |
Mar 11 2023, 11:53 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
Collecting the bits for my project, (4 to 6) rear brake question...
Are the rear 4 rotors the same thickness as 6? If so, can the 4 rear calipers (with their parking brake) be used? I am doing the 5-lug. Thanks in advance |
| mgphoto |
Mar 11 2023, 05:45 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Collecting the bits for my project, (4 to 6) rear brake question... Are the rear 4 rotors the same thickness as 6? If so, can the 4 rear calipers (with their parking brake) be used? I am doing the 5-lug. Thanks in advance You want to make sure that the holes to locate the brake disk and hub line up, if not the disk can cause an out of balance situation. |
| mepstein |
Mar 11 2023, 06:48 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Collecting the bits for my project, (4 to 6) rear brake question... Are the rear 4 rotors the same thickness as 6? If so, can the 4 rear calipers (with their parking brake) be used? I am doing the 5-lug. Thanks in advance You want to make sure that the holes to locate the brake disk and hub line up, if not the disk can cause an out of balance situation. I don’t believe that’s true. The two holes hold the rotor to the hub but have nothing to do with balance. If you don’t bolt the rotor to the hub, bolting the wheel on will keep the rotor in place. |
| mgphoto |
Mar 11 2023, 07:11 PM
Collecting the bits for my project, (4 to 6) rear brake question... Are the rear 4 rotors the same thickness as 6? If so, can the 4 rear calipers (with their parking brake) be used? I am doing the 5-lug. Thanks in advance You want to make sure that the holes to locate the brake disk and hub line up, if not the disk can cause an out of balance situation. I don’t believe that’s true. The two holes hold the rotor to the hub but have nothing to do with balance. If you don’t bolt the rotor to the hub, bolting the wheel on will keep the rotor in place. The screws center the disk to the hub, several mm play between the lugs and the disk. |
bossboy302 4 to 6 conversion: rear brakes Mar 11 2023, 11:53 AM
mgphoto
Collecting the bits for my project, (4 to 6) rear... Mar 11 2023, 12:01 PM
Superhawk996 The real reason to go to /6 calipers is due to the... Mar 11 2023, 12:31 PM
Collecting the bits for my project, (4 to 6) rear... Mar 11 2023, 01:24 PM
mlindner Or if you are not in need of the parking brake, yo... Mar 11 2023, 01:40 PM
Eric_Shea
Or if you are not in need of the parking brake, y... Mar 14 2023, 10:34 AM
bossboy302 Thanks all for quick replies...
Have done some re... Mar 11 2023, 01:58 PM
zoomCat Be aware that the 911 brakes on the front have a p... Mar 11 2023, 03:09 PM
Have done some r... Mar 11 2023, 03:14 PM
bossboy302 Ohhh....I probably got the nomenclature wrong, I m... Mar 11 2023, 04:04 PM
Ohhh....I probably got the nomenclature wrong, I ... Mar 11 2023, 04:07 PM
bossboy302 Hoping these would work...
https://www.pelicanpar... Mar 11 2023, 04:19 PM
https://www.pelicanpa... Mar 11 2023, 04:28 PM
bossboy302 IIIII...like it!
That is my hope. I thought b... Mar 11 2023, 04:40 PM
[quote name='mgphoto' post='3064301' date='Mar 1... Mar 11 2023, 07:52 PM
technicalninja Those flanges allow the 914/6 rear rotors to use b... Mar 11 2023, 07:45 PM
technicalninja Not having one of the screws installed doesn't... Mar 11 2023, 07:55 PM
Chris914n6 Rear rotor centers from the backside on the outer ... Mar 11 2023, 10:15 PM
Rear rotor centers from the backside on the outer... Mar 12 2023, 07:48 AM
Steve Compare the pad size of a 914-4 rear caliper to a ... Mar 12 2023, 12:35 AM
zoomCat
Compare the pad size of a 914-4 rear caliper to a... Mar 12 2023, 12:06 PM
Superhawk996
Compare the pad size of a 914-4 rear caliper to ... Mar 12 2023, 01:02 PM
zoomCat
[quote name='zoomCat' post='3064542' date='Mar 12... Mar 12 2023, 01:40 PM
[quote name='zoomCat' post='3064542' date='Mar 1... Mar 12 2023, 01:46 PM
zoomCat
Yes. 914-6 rear calipers are basically an M calip... Mar 12 2023, 01:59 PM
Eric_Shea
Yes. 914-6 rear calipers are basically an M cali... Mar 14 2023, 10:39 AM
technicalninja
Rear rotor centers from the backside on the outer... Mar 12 2023, 12:42 AM
mb911 One note for those thinking about doing this. I al... Mar 12 2023, 02:11 PM
hencar I agree with Ben and admittedly haven't read a... Mar 12 2023, 04:44 PM
Montreal914 Actually, rear rotors are different in thickness. ... Mar 13 2023, 09:12 AM
Actually, rear rotors are different in thickness.... Mar 13 2023, 09:29 AM
Eric_Shea
Actually, rear rotors are different in thickness.... Mar 14 2023, 10:40 AM
dr914@autoatlanta.com we can use stock six rotors with the aftermarket 9... Mar 13 2023, 09:39 AM
dflesburg Here is how I made it work
911 rear brakes - e br... Mar 14 2023, 06:46 AM
JmuRiz Eric, is it possible to space out a stock 914/4 re... Mar 14 2023, 10:40 AM
Eric_Shea
Eric, is it possible to space out a stock 914/4 r... Mar 14 2023, 10:44 AM
JmuRiz
Eric, is it possible to space out a stock 914/4 ... Mar 14 2023, 01:07 PM
Eric_Shea
[quote name='Eric_Shea' post='3065024' date='Mar ... Mar 15 2023, 08:50 AM
mgphoto See photo
I’m using the vented r... Mar 14 2023, 11:26 AM
rudedude Does anyone have experience with the URO hub for 5... Mar 15 2023, 08:45 AM
Eric_Shea
Does anyone have experience with the URO hub for ... Mar 15 2023, 09:57 AM
rudedude Thanks Eric for the encouraging words
Jule Mar 15 2023, 01:03 PM
IronHillRestorations If you want 914-6 rear calipers, send me a PM. I h... Mar 15 2023, 07:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:41 AM |
