914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I am replacing the calipers on my car. After pumping the old fluid out, we realized the soft lines needed repair (they were fine before). Now, there is a link under the car that appears to be coming from the master cylinder:
![]() The dark areas are wet with brake fluid. Here is a closeup of the master cylinder. The dark areas are wet. The only spot that is not wet (yet) is the lighter area on the lower left: ![]() I have checked the reservoir at the top and it is fine. The fluid is coming from somewhere down here. Please advise! Thanks! -Jeff ----------- |
914 RZ-1 |
I got it off. I just needed to pull it out a little to get some leverage. They popped off with some effort.
Thanks for the heads up on the washers. I haven't got the old rubber off the old MC; I'm guessing they are under there? I've cleaned the floor. There was brake fluid all over that lower area. I've also cleaned the pedal assembly. I'm letting it dry out, then wire brush and some sort of anti-rust paint. Do they make POR15 in something I can brush on? I usually use Rust Reformer spray paint. |
Lo-Fi Version | Time is now: 7th September 2025 - 09:09 AM |
