| seanpaulmc |
Mar 11 2023, 07:26 PM
Member ![]() ![]() Group: Members Posts: 445 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
After the hell hole repair, I have the engine shelf to repair/replace. Question for those of you who have done this before, I’m trying to decide on splicing in a short repair section or trying to extract the remaining original panel and install the whole new RD panel. The latter being the most work.
Not a special car in terms of rarity, options, or other. Been doing lots of rust repair. Just not sure how to tackle it yet. Thanks ![]() ![]() Look forward to hearing your feedback. |
| Ishley |
Mar 12 2023, 12:02 PM
Member ![]() ![]() Group: Members Posts: 339 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Just to be clear…
You don’t just replace the channel for rubber. Go to restoration design and you’ll see a picture of the whole engine shelf with the channel already attached. On mine I replaced almost all of it… but made a cut near the rear and butt welded that back part. Not sure if this clears it up. Also… restoration design has a video about installing the shelf. |
| seanpaulmc |
Mar 12 2023, 12:30 PM
Just to be clear… You don’t just replace the channel for rubber. Go to restoration design and you’ll see a picture of the whole engine shelf with the channel already attached. On mine I replaced almost all of it… but made a cut near the rear and butt welded that back part. Not sure if this clears it up. Also… restoration design has a video about installing the shelf. I appreciate the explanation. Yes, I already have RD part in hand. It’s so well made which is why I was thinking of attempting to do the whole part. However, splicing in the forward portion where the engine shelf is the most narrow seems like a good alternative to tearing into the rear portion where it is solid and in good shape…and has paint. Again, I appreciate the feedback. Thanks |
seanpaulmc Engine shelf replacement- Mar 11 2023, 07:26 PM
914werke Done it both ways.
Actually there are 3 ways... C... Mar 11 2023, 07:57 PM
windforfun
Done it both ways.
Actually there are 3 ways... ... Mar 11 2023, 08:05 PM
Dlee6205 I typically splice it right at the rear of the sus... Mar 11 2023, 08:04 PM
seanpaulmc
I typically splice it right at the rear of the su... Mar 11 2023, 08:54 PM
bkrantz I spliced a section of shelf, about where yours is... Mar 11 2023, 08:45 PM
Dlee6205
I typically splice it right at the rear of the s... Mar 12 2023, 08:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 11:36 AM |
