| technicalninja |
Mar 12 2023, 01:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Quick couple of questions:
What is the difference between 1.8l gasket sets and 2.0 sets? Is it just the head gaskets and a different intake gasket? 2.0 is out of stock almost everywhere and what's available is expensive. I'm planning on using 96mm head gaskets anyway so the gaskets which come in a 2.0 kit will not be used. I found copper 96mm gaskets on Aircooled.net and will either use them or none at all. I'm planning on a quench distance of .035" using hypereutectic pistons and it might be beneficial to use no gaskets at all. What are you guys using for front and rear main seals? Seems the good ones are discontinued and I'm not sure what the best options are now. Do you anneal the exhaust copper seals when new or are they dead soft initially? What are my options guys? I'm very brand specific when I know which brand is best. Right now, I don't have this knowledge. The target engine is a 73 2.0l |
| Superhawk996 |
Mar 12 2023, 04:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,913 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
You might want to take a look at 0.035” that is getting tight. Not sure anyone out there is recommending below 0.040” on the tight end.
Maybe you’re doing other things to manage valve clearance, rod stretch, and compression ratios. Just be aware that is getting tight. |
technicalninja gasket set differences. Mar 12 2023, 01:54 PM
914werke Do some searching here. There is a strong debate f... Mar 12 2023, 02:22 PM
Freezin 914
Do some searching here. There is a strong debate ... Mar 12 2023, 02:51 PM
technicalninja I'm leaning that way.
Removing any extraneous ... Mar 12 2023, 02:43 PM
914sgofast2 There is a Jake Raby video on rear main seals now ... Mar 12 2023, 03:02 PM
930cabman My last build I lapped the cast iron cylinders (AA... Mar 12 2023, 04:23 PM
Dave_Darling The muffler gaskets would also be different. Also... Mar 13 2023, 05:11 AM
technicalninja
The muffler gaskets would also be different. Als... Mar 13 2023, 08:28 AM
technicalninja
My last build I lapped the cast iron cylinders (A... Mar 13 2023, 08:53 AM
930cabman
My last build I lapped the cast iron cylinders (... Mar 13 2023, 12:32 PM
yeahmag Didn't aircooled.net shutdown? Mar 13 2023, 06:36 PM
r_towle Go to one of the main aircooled shops.
https://ww... Mar 13 2023, 06:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 09:59 PM |
