| bkrantz |
Mar 11 2023, 09:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,775 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) |
| VaccaRabite |
Mar 13 2023, 07:47 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,914 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Well, lets see... I have a tie I think.
1) after checking compression on my engine, I did not realize that the compression hose had unscrewed from the spark bore adapter on the #2 cylinder. I screwed in the spark plug to the compression adapter (they were the same thread and went in easy). I did not notice that the plug was sitting about 1.5inches higher then usual. Drove around pissed off that I had a really bad miss on one of my cylinders after spring maintenance... 2) While doing work on the dizzy, the little spring at the bottom of the distributor shaft somehow went down the tiny hole offset in the dizzy shaft bore and into the engine case. I had to get under the car, lower the nose of the engine, pull the oil pump out and fish out the spring. It was a hot humid day and I was coated in sweat and oil by the time I rolled out from under the car. Zach |
bkrantz Dumbest Thing Mar 11 2023, 09:02 PM
Craigers17 I did something very similar a couple months ago. ... Mar 12 2023, 06:22 AM
930cabman Last winter I built a 2056, got her on the stand a... Mar 12 2023, 06:56 AM
76-914 Last week my turn signals quit working on a short ... Mar 12 2023, 09:15 AM
gandalf_025 I had a body shop cut down my 914-6 rear snowplow ... Mar 12 2023, 02:54 PM
gandalf_025 I also bought a complete 1965, 911 engine
over an ... Mar 12 2023, 03:01 PM
windforfun Drove my new Scirocco too close to the curb at a f... Mar 12 2023, 03:13 PM
infraredcalvin Daughters first time driving, I pulled into an emp... Mar 12 2023, 06:52 PM
DBF Wanted to celebrate my birthday by doing some work... Mar 12 2023, 07:06 PM
914 RZ-1 I took my transmission out, but, when putting it b... Mar 12 2023, 08:36 PM
jhynesrockmtn I had pulled the engine on my 70 to fix a bunch of... Mar 12 2023, 09:20 PM
930cabman Thanks all for the laughs, keep them coming Mar 13 2023, 04:55 AM
DRPHIL914 probably a dozen things.... we should call these t... Mar 13 2023, 06:55 AM
ClayPerrine I rebuilt a 901 trans in a 71 911 years ago. I di... Mar 13 2023, 06:58 AM
76-914
I rebuilt a 901 trans in a 71 911 years ago. I d... Mar 13 2023, 08:59 AM
ClayPerrine
I rebuilt a 901 trans in a 71 911 years ago. I ... Mar 13 2023, 09:27 AM
Root_Werks Have a bunch of these stories, these two got me be... Mar 13 2023, 08:46 AM
dr914@autoatlanta.com 1979 had a 914 sold and promised the guy a clutch ... Mar 13 2023, 12:07 PM
dr914@autoatlanta.com RE: Dumbest Thing Mar 13 2023, 12:08 PM
relentless I don't know if it's the dumbest thing I... Mar 13 2023, 12:58 PM
jfort
I don't know if it's the dumbest thing I... Mar 16 2023, 03:04 PM
fiacra I alternate between thinking it was the dumbest th... Mar 13 2023, 03:21 PM
tygaboy
I alternate between thinking it was the dumbest t... Mar 13 2023, 04:38 PM
barefoot Perhaps not dumbest thing, but scared me crazy doi... Mar 15 2023, 08:39 AM
930cabman
Perhaps not dumbest thing, but scared me crazy do... Mar 15 2023, 08:45 AM
barefoot
Perhaps not dumbest thing, but scared me crazy d... Mar 16 2023, 06:09 AM
technicalninja Trusting the machine shop...
I once built a 74 Fi... Mar 16 2023, 10:11 AM
Superhawk996
I trusted them and assembled the Fiat (my own c... Mar 16 2023, 11:13 AM
bkrantz
I trusted them and assembled the Fiat (my own ... Mar 16 2023, 10:13 PM
ClayPerrine
[quote name='Superhawk996' post='3065501' date='M... Mar 17 2023, 05:25 AM
technicalninja Compared to what was available at the time a Fiat ... Mar 16 2023, 01:51 PM
barefoot
Compared to what was available at the time a Fiat... Mar 17 2023, 01:14 PM
jfort Had the car on the lift, headers off, and adjusted... Mar 16 2023, 02:54 PM
lolkema my brightest moment was when I had just finished a... Mar 18 2023, 06:28 PM
930cabman
my brightest moment was when I had just finished ... Mar 19 2023, 05:53 AM
lolkema
my brightest moment was when I had just finished... Mar 19 2023, 11:12 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 11:57 PM |
