> 17mm vs 19mm master brake cylinder, pros and cons?
914 RZ-1
post Mar 12 2023, 05:33 PM
Porsche Padawan
I need a new M/C. Stock is 17mm, but it seems everyone is selling 19mm. I'll get a firmer pedal and less stroke with the 19mm, correct? Is this good or bad or personal preference?
What are the advantages/disadvantages of both?
Thanks!
-Jeff
Eric_Shea
post Mar 13 2023, 01:22 PM
PMB Performance
In a "real world" application, the feel between a 17mm and a 19mm is (as @76-914 mentions) basically indistinguishable. I'm certain it can be measured but you "really" won't noticed it. There will be no leg fatigue whatsoever. I'll buy you a protein shake the next time I see you if you get leg fatigue pressing your brake pedal. (IMG:style_emoticons/default/cheer.gif)
This 17 vs. 19 is just a non-issue that gets way overblown via the Itnerweb thingy.
The real issue (as the OP is finding) is there are no more 17's being made. None of the suppliers carry them. And so goes the 17... so should threads like this. (IMG:style_emoticons/default/biggrin.gif)
I've also found that a "harder" pedal gives me the best modulation. The feedback and feel in the foot is extremely precise with a harder pedal. YMMV (IMG:style_emoticons/default/wink.gif)
(fire away)
914 RZ-1   17mm vs 19mm master brake cylinder   Mar 12 2023, 05:33 PM
JeffBowlsby   I need a new M/C. Stock is 17mm, but it seems eve...   Mar 12 2023, 05:39 PM
mepstein   19mm - moves more fluid, less pedal travel. Needs ...   Mar 12 2023, 05:42 PM
914 RZ-1   19mm - moves more fluid, less pedal travel. Needs...   Mar 12 2023, 07:45 PM
Superhawk996   I need a new M/C. Stock is 17mm, but it seems eve...   Mar 12 2023, 05:54 PM
914 RZ-1   [quote name='914 RZ-1' post='3064607' date='...   Mar 12 2023, 07:50 PM
914werke   19mm - moves more fluid, less pedal travel. Needs...   Mar 12 2023, 05:58 PM
mepstein   Make sure you replace all your soft rubber lines i...   Mar 12 2023, 06:15 PM
914 RZ-1   Make sure you replace all your soft rubber lines ...   Mar 12 2023, 07:44 PM
914Toy   It also depends on which calipers you are using. ...   Mar 12 2023, 07:26 PM
914 RZ-1   It also depends on which calipers you are using. ...   Mar 12 2023, 07:47 PM
914 RZ-1   Thanks for the replies! I did search this site...   Mar 12 2023, 07:43 PM
Superhawk996   17mm m/c are indeed hard to come by. NOS pops up ...   Mar 12 2023, 08:06 PM
76-914   I installed one of Mark's 19mm when the 17mm w...   Mar 12 2023, 08:24 PM
Cairo94507   Just because, I have a 23mm master cylinder, 914-6...   Mar 13 2023, 08:03 AM
mepstein   PMB sells Porterfield brake pads. I’ve been real...   Mar 13 2023, 08:52 AM
Eric_Shea   In a "real world" application, the feel ...   Mar 13 2023, 01:22 PM
mgp4591   In a "real world" application, the feel...   Mar 14 2023, 07:07 AM
bkrantz   At the risk of high-jacking (sorry) what can be do...   Mar 13 2023, 08:38 PM
Eric_Shea   At the risk of high-jacking (sorry) what can be d...   Mar 14 2023, 10:28 AM
bkrantz   At the risk of high-jacking (sorry) what can be ...   Mar 14 2023, 08:01 PM
76-914   IMHO, I try to avoid locking up the brakes. You ca...   Mar 13 2023, 10:30 PM
bkrantz   IMHO, I try to avoid locking up the brakes. You c...   Mar 14 2023, 07:59 PM
Superhawk996   :agree: People have become used to overboosted b...   Mar 14 2023, 05:55 PM
bkrantz   :agree: People have become used to overboosted ...   Mar 14 2023, 08:05 PM
930cabman   :agree: People have become used to overboosted ...   Mar 16 2023, 06:23 AM
914werke   In a "real world" application, the feel...   Mar 16 2023, 12:08 PM
- Lo-Fi Version Time is now: 23rd September 2025 - 12:14 AM
