> 17mm vs 19mm master brake cylinder, pros and cons?
914 RZ-1
post Mar 12 2023, 05:33 PM
Porsche Padawan
I need a new M/C. Stock is 17mm, but it seems everyone is selling 19mm. I'll get a firmer pedal and less stroke with the 19mm, correct? Is this good or bad or personal preference?
What are the advantages/disadvantages of both?
Thanks!
-Jeff
bkrantz
post Mar 13 2023, 08:38 PM
At the risk of high-jacking (sorry) what can be done to maximize braking power (real and perception) with the stock system?
As part of my build, I completely overhauled the brakes, with 4 calipers and rear pressure valve rebuilt by PMB, all new lines and hoses, new Porterfield pads, new disks, and a new ATE 19mm MC. I did lots (LOTS! of bleeding) and had a very firm pedal. And I carefully did the bedding procedure that PMB recommends. But the brake power always seemed lacking. I could get one or both front wheels to lock up (barely) if I really stood on the pedal.
@Eric_Shea , and others, any comments?
Eric_Shea
post Mar 14 2023, 10:28 AM
PMB Performance
QUOTE(bkrantz @ Mar 13 2023, 08:38 PM) *
The biggest part of this equation is realizing it's a 50 year old non-boosted brake system. Mom's minivan and your pinky toe can do better by today's standards.
Depending upon the front struts, you could easily go up to say... 911RS braking power but, I don't think that would do what you want it to either. (IMG:style_emoticons/default/huh.gif)
If you daily a 914 (which most of us don't do), it becomes "normal". If you daily a 2019 ______, that becomes normal and a 914 tends to feel bad.
Aside from a boosted circuit, this is a difficult (yet extremely common) question to answer with all the variables. My answer comes from living with 914 brake systems for 42 years and dealing with this question for almost 20 years. I think they're not only adequate but "extremely good" by 1970-76 standards.
bkrantz
post Mar 14 2023, 08:01 PM
QUOTE(Eric_Shea @ Mar 14 2023, 09:28 AM) *
Thanks, Eric. I have tried to account for my modern brake bias (no pun intended). I did have Mike M drive my car last summer, and he also thought the brakes should be better.
914 RZ-1   17mm vs 19mm master brake cylinder   Mar 12 2023, 05:33 PM
JeffBowlsby   I need a new M/C. Stock is 17mm, but it seems eve...   Mar 12 2023, 05:39 PM
mepstein   19mm - moves more fluid, less pedal travel. Needs ...   Mar 12 2023, 05:42 PM
914 RZ-1   19mm - moves more fluid, less pedal travel. Needs...   Mar 12 2023, 07:45 PM
Superhawk996   I need a new M/C. Stock is 17mm, but it seems eve...   Mar 12 2023, 05:54 PM
914 RZ-1   [quote name='914 RZ-1' post='3064607' date='...   Mar 12 2023, 07:50 PM
914werke   19mm - moves more fluid, less pedal travel. Needs...   Mar 12 2023, 05:58 PM
mepstein   Make sure you replace all your soft rubber lines i...   Mar 12 2023, 06:15 PM
914 RZ-1   Make sure you replace all your soft rubber lines ...   Mar 12 2023, 07:44 PM
914Toy   It also depends on which calipers you are using. ...   Mar 12 2023, 07:26 PM
914 RZ-1   It also depends on which calipers you are using. ...   Mar 12 2023, 07:47 PM
914 RZ-1   Thanks for the replies! I did search this site...   Mar 12 2023, 07:43 PM
Superhawk996   17mm m/c are indeed hard to come by. NOS pops up ...   Mar 12 2023, 08:06 PM
76-914   I installed one of Mark's 19mm when the 17mm w...   Mar 12 2023, 08:24 PM
Cairo94507   Just because, I have a 23mm master cylinder, 914-6...   Mar 13 2023, 08:03 AM
mepstein   PMB sells Porterfield brake pads. I’ve been real...   Mar 13 2023, 08:52 AM
Eric_Shea   In a "real world" application, the feel ...   Mar 13 2023, 01:22 PM
mgp4591   In a "real world" application, the feel...   Mar 14 2023, 07:07 AM
bkrantz   At the risk of high-jacking (sorry) what can be do...   Mar 13 2023, 08:38 PM
Eric_Shea   At the risk of high-jacking (sorry) what can be d...   Mar 14 2023, 10:28 AM
bkrantz   At the risk of high-jacking (sorry) what can be ...   Mar 14 2023, 08:01 PM
76-914   IMHO, I try to avoid locking up the brakes. You ca...   Mar 13 2023, 10:30 PM
bkrantz   IMHO, I try to avoid locking up the brakes. You c...   Mar 14 2023, 07:59 PM
Superhawk996   :agree: People have become used to overboosted b...   Mar 14 2023, 05:55 PM
bkrantz   :agree: People have become used to overboosted ...   Mar 14 2023, 08:05 PM
930cabman   :agree: People have become used to overboosted ...   Mar 16 2023, 06:23 AM
914werke   In a "real world" application, the feel...   Mar 16 2023, 12:08 PM
- Lo-Fi Version Time is now: 23rd September 2025 - 12:13 AM
