| bossboy302 |
Mar 11 2023, 11:53 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
Collecting the bits for my project, (4 to 6) rear brake question...
Are the rear 4 rotors the same thickness as 6? If so, can the 4 rear calipers (with their parking brake) be used? I am doing the 5-lug. Thanks in advance |
| rudedude |
Mar 15 2023, 08:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
Does anyone have experience with the URO hub for 5 bolt conversion? Just wondering about the uro part and their reputation.
bossboy302 4 to 6 conversion: rear brakes Mar 11 2023, 11:53 AM
mgphoto
Collecting the bits for my project, (4 to 6) rear... Mar 11 2023, 12:01 PM
Superhawk996 The real reason to go to /6 calipers is due to the... Mar 11 2023, 12:31 PM
Collecting the bits for my project, (4 to 6) rear... Mar 11 2023, 01:24 PM
mlindner Or if you are not in need of the parking brake, yo... Mar 11 2023, 01:40 PM
Eric_Shea
Or if you are not in need of the parking brake, y... Mar 14 2023, 10:34 AM
bossboy302 Thanks all for quick replies...
Have done some re... Mar 11 2023, 01:58 PM
zoomCat Be aware that the 911 brakes on the front have a p... Mar 11 2023, 03:09 PM
Have done some r... Mar 11 2023, 03:14 PM
bossboy302 Ohhh....I probably got the nomenclature wrong, I m... Mar 11 2023, 04:04 PM
Ohhh....I probably got the nomenclature wrong, I ... Mar 11 2023, 04:07 PM
bossboy302 Hoping these would work...
https://www.pelicanpar... Mar 11 2023, 04:19 PM
https://www.pelicanpa... Mar 11 2023, 04:28 PM
bossboy302 IIIII...like it!
That is my hope. I thought b... Mar 11 2023, 04:40 PM
mgphoto
Collecting the bits for my project, (4 to 6) rear... Mar 11 2023, 05:45 PM
Collecting the bits for my project, (4 to 6) rea... Mar 11 2023, 06:48 PM
mgphoto
[quote name='mgphoto' post='3064301' date='Mar 11... Mar 11 2023, 07:11 PM
[quote name='mgphoto' post='3064301' date='Mar 1... Mar 11 2023, 07:52 PM
technicalninja Those flanges allow the 914/6 rear rotors to use b... Mar 11 2023, 07:45 PM
technicalninja Not having one of the screws installed doesn't... Mar 11 2023, 07:55 PM
Chris914n6 Rear rotor centers from the backside on the outer ... Mar 11 2023, 10:15 PM
Rear rotor centers from the backside on the outer... Mar 12 2023, 07:48 AM
Steve Compare the pad size of a 914-4 rear caliper to a ... Mar 12 2023, 12:35 AM
zoomCat
Compare the pad size of a 914-4 rear caliper to a... Mar 12 2023, 12:06 PM
Superhawk996
Compare the pad size of a 914-4 rear caliper to ... Mar 12 2023, 01:02 PM
zoomCat
[quote name='zoomCat' post='3064542' date='Mar 12... Mar 12 2023, 01:40 PM
[quote name='zoomCat' post='3064542' date='Mar 1... Mar 12 2023, 01:46 PM
zoomCat
Yes. 914-6 rear calipers are basically an M calip... Mar 12 2023, 01:59 PM
Eric_Shea
Yes. 914-6 rear calipers are basically an M cali... Mar 14 2023, 10:39 AM
technicalninja
Rear rotor centers from the backside on the outer... Mar 12 2023, 12:42 AM
mb911 One note for those thinking about doing this. I al... Mar 12 2023, 02:11 PM
hencar I agree with Ben and admittedly haven't read a... Mar 12 2023, 04:44 PM
Montreal914 Actually, rear rotors are different in thickness. ... Mar 13 2023, 09:12 AM
Actually, rear rotors are different in thickness.... Mar 13 2023, 09:29 AM
Eric_Shea
Actually, rear rotors are different in thickness.... Mar 14 2023, 10:40 AM
dr914@autoatlanta.com we can use stock six rotors with the aftermarket 9... Mar 13 2023, 09:39 AM
dflesburg Here is how I made it work
911 rear brakes - e br... Mar 14 2023, 06:46 AM
JmuRiz Eric, is it possible to space out a stock 914/4 re... Mar 14 2023, 10:40 AM
Eric_Shea
Eric, is it possible to space out a stock 914/4 r... Mar 14 2023, 10:44 AM
JmuRiz
Eric, is it possible to space out a stock 914/4 ... Mar 14 2023, 01:07 PM
Eric_Shea
[quote name='Eric_Shea' post='3065024' date='Mar ... Mar 15 2023, 08:50 AM
mgphoto See photo
<āāā-
Iām using the vented r... Mar 14 2023, 11:26 AM
Eric_Shea
Does anyone have experience with the URO hub for ... Mar 15 2023, 09:57 AM
rudedude Thanks Eric for the encouraging words
Jule Mar 15 2023, 01:03 PM
IronHillRestorations If you want 914-6 rear calipers, send me a PM. I h... Mar 15 2023, 07:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:49 AM |
