> 4 to 6 conversion: rear brakes
bossboy302
post Mar 11 2023, 11:53 AM
Collecting the bits for my project, (4 to 6) rear brake question...
Are the rear 4 rotors the same thickness as 6?
If so, can the 4 rear calipers (with their parking brake) be used?
I am doing the 5-lug.
Thanks in advance
JmuRiz
post Mar 14 2023, 10:40 AM
Eric, is it possible to space out a stock 914/4 rear caliper to use vented rear disks?
Eric_Shea
post Mar 14 2023, 10:44 AM
PMB Performance
QUOTE(JmuRiz @ Mar 14 2023, 10:40 AM) *
Yes, but "why?" is the question.
A stock 914 rear caliper will never heat up a solid rotor enough to require a vented rear. We had them made in the past but when you look into it, it just doesn't make sense.
BMW 3.0CSi rear calipers have the spacers and the fasteners required for this conversion. Hens teeth (IMG:style_emoticons/default/wink.gif)
JmuRiz
post Mar 14 2023, 01:07 PM
QUOTE(Eric_Shea @ Mar 14 2023, 08:44 AM) *
Good to know, I have solids and will relay this into to me brother. Easier to go back to 914/4 rears and solid disks than fab up a 911 style e-brake. I'm sure he'll write you about while waiting for his 2300i
Eric_Shea
post Mar 15 2023, 08:50 AM
PMB Performance
QUOTE(JmuRiz @ Mar 14 2023, 01:07 PM) *
Aa's going on the engine run-in stand today. Zach should be out the door... (IMG:style_emoticons/default/wink.gif)
bossboy302   4 to 6 conversion: rear brakes   Mar 11 2023, 11:53 AM
mgphoto   Collecting the bits for my project, (4 to 6) rear...   Mar 11 2023, 12:01 PM
Superhawk996   The real reason to go to /6 calipers is due to the...   Mar 11 2023, 12:31 PM
mepstein   Collecting the bits for my project, (4 to 6) rear...   Mar 11 2023, 01:24 PM
mlindner   Or if you are not in need of the parking brake, yo...   Mar 11 2023, 01:40 PM
Eric_Shea   Or if you are not in need of the parking brake, y...   Mar 14 2023, 10:34 AM
bossboy302   Thanks all for quick replies... Have done some re...   Mar 11 2023, 01:58 PM
zoomCat   Be aware that the 911 brakes on the front have a p...   Mar 11 2023, 03:09 PM
mepstein   Thanks all for quick replies... Have done some r...   Mar 11 2023, 03:14 PM
bossboy302   Ohhh....I probably got the nomenclature wrong, I m...   Mar 11 2023, 04:04 PM
mepstein   Ohhh....I probably got the nomenclature wrong, I ...   Mar 11 2023, 04:07 PM
bossboy302   Hoping these would work... https://www.pelicanpar...   Mar 11 2023, 04:19 PM
mepstein   Hoping these would work... https://www.pelicanpa...   Mar 11 2023, 04:28 PM
bossboy302   IIIII...like it! That is my hope. I thought b...   Mar 11 2023, 04:40 PM
mgphoto   Collecting the bits for my project, (4 to 6) rear...   Mar 11 2023, 05:45 PM
mepstein   Collecting the bits for my project, (4 to 6) rea...   Mar 11 2023, 06:48 PM
mgphoto   [quote name='mgphoto' post='3064301' date='Mar 11...   Mar 11 2023, 07:11 PM
mepstein   [quote name='mgphoto' post='3064301' date='Mar 1...   Mar 11 2023, 07:52 PM
technicalninja   Those flanges allow the 914/6 rear rotors to use b...   Mar 11 2023, 07:45 PM
technicalninja   Not having one of the screws installed doesn't...   Mar 11 2023, 07:55 PM
Chris914n6   Rear rotor centers from the backside on the outer ...   Mar 11 2023, 10:15 PM
mepstein   Rear rotor centers from the backside on the outer...   Mar 12 2023, 07:48 AM
Steve   Compare the pad size of a 914-4 rear caliper to a ...   Mar 12 2023, 12:35 AM
zoomCat   Compare the pad size of a 914-4 rear caliper to a...   Mar 12 2023, 12:06 PM
Superhawk996   Compare the pad size of a 914-4 rear caliper to ...   Mar 12 2023, 01:02 PM
zoomCat   [quote name='zoomCat' post='3064542' date='Mar 12...   Mar 12 2023, 01:40 PM
mepstein   [quote name='zoomCat' post='3064542' date='Mar 1...   Mar 12 2023, 01:46 PM
zoomCat   Yes. 914-6 rear calipers are basically an M calip...   Mar 12 2023, 01:59 PM
Eric_Shea   Yes. 914-6 rear calipers are basically an M cali...   Mar 14 2023, 10:39 AM
technicalninja   Rear rotor centers from the backside on the outer...   Mar 12 2023, 12:42 AM
mb911   One note for those thinking about doing this. I al...   Mar 12 2023, 02:11 PM
hencar   I agree with Ben and admittedly haven't read a...   Mar 12 2023, 04:44 PM
Montreal914   Actually, rear rotors are different in thickness. ...   Mar 13 2023, 09:12 AM
mepstein   Actually, rear rotors are different in thickness....   Mar 13 2023, 09:29 AM
Eric_Shea   Actually, rear rotors are different in thickness....   Mar 14 2023, 10:40 AM
dr914@autoatlanta.com   we can use stock six rotors with the aftermarket 9...   Mar 13 2023, 09:39 AM
dflesburg   Here is how I made it work 911 rear brakes - e br...   Mar 14 2023, 06:46 AM
JmuRiz   Eric, is it possible to space out a stock 914/4 re...   Mar 14 2023, 10:40 AM
Eric_Shea   Eric, is it possible to space out a stock 914/4 r...   Mar 14 2023, 10:44 AM
JmuRiz   Eric, is it possible to space out a stock 914/4 ...   Mar 14 2023, 01:07 PM
Eric_Shea   [quote name='Eric_Shea' post='3065024' date='Mar ...   Mar 15 2023, 08:50 AM
mgphoto   See photo <———- I’m using the vented r...   Mar 14 2023, 11:26 AM
rudedude   Does anyone have experience with the URO hub for 5...   Mar 15 2023, 08:45 AM
Eric_Shea   Does anyone have experience with the URO hub for ...   Mar 15 2023, 09:57 AM
rudedude   Thanks Eric for the encouraging words Jule   Mar 15 2023, 01:03 PM
IronHillRestorations   If you want 914-6 rear calipers, send me a PM. I h...   Mar 15 2023, 07:25 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:49 AM
