| Robarabian |
Mar 15 2023, 08:48 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
I have a 911 engine I am working on. I am practicing setting cam timing so I can feel comfortable with it prior to the tear down. My Crankshaft pulley has a Z1 mark that has 2 lines. So I have seen 911 pulleys with Z1 and 1 line.
The question de jour is which of the 2 lines at Z1 is TDC? Or are the 2 lines giving me the dwell of where TDC is and if so, where should I put them in relation to the case to set cam timing and do valve adjustments. it looks like " Z | | 1" It is a 2.4 Somebody knows this answer. |
| IronHillRestorations |
Mar 16 2023, 03:06 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,922 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
To add confusion the 2.4 and 2.7’s crank is indexed differently than the 2.0 and 2.2’s.
You can use a 2.0 (same as 914-6) flywheel on 2.0-2.7 and it will bolt up, but with 2.4 and 2.7 the timing marks on the flywheel will be off. I always re-mark Z1, 35*, 120*, and 240*. With a 6 it’s much easier to set the timing and adjust the valves using the marks on the flywheel. |
| Robarabian |
Mar 16 2023, 06:45 PM
I was wondering about that. I installed a new flywheel on the 2.7 motor when I was working on it and was confused about why the Z1 mark on the pulley didn't line up with the Z1 on the flywheel. I ended up marking it as you said.
To add confusion the 2.4 and 2.7’s crank is indexed differently than the 2.0 and 2.2’s. You can use a 2.0 (same as 914-6) flywheel on 2.0-2.7 and it will bolt up, but with 2.4 and 2.7 the timing marks on the flywheel will be off. I always re-mark Z1, 35*, 120*, and 240*. With a 6 it’s much easier to set the timing and adjust the valves using the marks on the flywheel. |
Robarabian Question for Six Engine People Mar 15 2023, 08:48 PM
Robarabian I may have found the answer looking at 50 differen... Mar 15 2023, 08:57 PM
targa72e That is correct . 911 of that vintage had vacuum r... Mar 15 2023, 10:33 PM
Krieger I think the 5° BTDC is the timing mark at idle. I... Mar 15 2023, 10:33 PM
ClayPerrine A suggestion for setting the cam timing.
Only pu... Mar 16 2023, 05:28 AM
gereed75 I would emphasize one of Clays comments -put a dia... Mar 16 2023, 09:57 AM
930cabman I would double check with a dial indicator Mar 16 2023, 11:58 AM
Robarabian So my pulley actually has the Z1 mark and the seco... Mar 16 2023, 06:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:58 AM |
