| Flat6forlife |
Mar 23 2023, 04:56 PM
Newbie ![]() Group: Members Posts: 3 Joined: 4-October 18 From: Babylon, NY Member No.: 22,542 Region Association: North East States |
Hey everyone,
I'm a few weeks away from dropping the drivetrain from my '73 1.7 for a refresh/rebuild. It's an IDF-carbed 2.4L (supposedly, I haven't cracked it open yet) that'll be used mostly for street driving but will see regular autocrosses and occasional track time, hence the dry sump. I've researched for a while and have a decent plan, but I'd love some insight from those who've put them together. As it stands, the current plan is as follows: 914/6 oil tank with the attached filter CB or Thorsten Pieper pump (I'd like to retain the OE fan) Tangerine Racing Oil Cooler and Thermostat setup with the fan Requisite braided AN lines with appropriate hardware I see that CSP also makes a pump, but I can't find anyone who has experience with them. The TP pump seems like the best way to go, but the only dry-sumped racer I've seen used the CB to much success. Money isn't an issue for the TP pump; I'll pay for the extra protection and/or simpler installation. The CB needs modification if I've read correctly. Does anyone have a preference? Also, using the 914/6 tank and its attached filter makes the original filter redundant. Should I run the LN oil filter block-off plate or use a filter relocation adapter to feed an oil cooler (with an inline thermostat) and leave the factory oil cooler in place for two coolers? Maybe double oil filters and the Tangerine oil cooler kit? I appreciate the insight/assistance! Also, if this has been beaten and covered to death anywhere else, please link it. I'm happy to read and learn that way. |
| BillJ |
Mar 23 2023, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
This setup monitors pressure and provides additonal oil when the engine oil pressure drops below a certain threshold. It also pre-oils prior to.startup to preserve hotter setups. Here is a pic as installed on my last 4 cylinder racer:
It was wired to activate as soon as power was turned on so delivered oil prior to ignition. A very efficient and simple system. Ultimately also less expensive perhaps than your current plan unless you already have the oil tank. |
Flat6forlife Putting together a Type IV dry sump system Mar 23 2023, 04:56 PM
BillJ You can go that way or just use what all the type ... Mar 23 2023, 05:02 PM
Superhawk996
You can go that way or just use what all the type... Mar 23 2023, 08:01 PM
gnomefabtech Accusump will keep the pressure up in a pinch but ... Mar 23 2023, 08:16 PM
Montreal914 Aaron @yeahmag has a proven and tested setup... Mar 23 2023, 08:35 PM
GregAmy I'm running a dry sump in my 914/4 2L 4-banger... Mar 23 2023, 08:35 PM
Flat6forlife
Glad to assist as I can, but not quite sure what... Mar 25 2023, 10:06 AM
Dave_Darling The biggest problem that I can see is the pump its... Mar 24 2023, 02:48 AM
GregAmy
Do you know if any of your chosen pumps will clea... Mar 24 2023, 05:53 AM
ClayPerrine The late Wes Hildreth built a 4 cylinder 914 with ... Mar 24 2023, 06:06 AM
ChrisFoley Here are two different vintages of CB Performance ... Mar 24 2023, 11:09 AM
914werke
Here are two different vintages of CB Performance... Mar 25 2023, 11:15 AM
ChrisFoley And I welded shut the threaded hole where the ther... Mar 26 2023, 06:17 AM
914werke And I welded shut the threaded hole where the the... Aug 3 2024, 10:33 PM
rhodyguy Dave Hunt installed a dry sump when he built his 2... Aug 4 2024, 11:12 AM
Shivers
Hey everyone,
I'm a few weeks away from drop... Aug 4 2024, 11:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:20 PM |
