| 914Sixer |
Mar 23 2023, 01:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,432 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I was able to purchase a VW Bus Axle. 914 axles are 20.25 in length and about 25mm in diameter. This bus axle is 20.50 in length and 28mm in diameter (double check the length on what you are buying). Best I can measure the CV's are in the same place with just 3mm on each end difference. The 914 axles I have look like they were ground off to make them shorter from the factory There is plenty of room in the 944 Turbo stub axle and the 915 transmission flange for movement. The axles are fully loaded and ready to go. Depending on where you shop you can pick up a pair shipped for less than $185. The only modification I see will be adding extra gasket on the transmission flange. To make these work you will need 944 stub axles and 915 transmission flanges.
The old original bus cv's had 17 degrees on angle. The new 944/bus cv's go a full 24 degrees. Stock 914 cv angle was 12 degrees. Will play around this weekend and see what comes up. Opinions? Attached image(s)
| rick 918-S |
Mar 24 2023, 06:02 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,223 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I thought that is what you meant. Thank you. PMB has the outboard part.
914Sixer Possible HD Axle Upgrade With 100mm CV's Mar 23 2023, 01:53 PM
technicalninja Very interesting!
What year Bus should you use... Mar 23 2023, 02:19 PM
rick 918-S Sorry I do not get what you are saying. Does this ... Mar 24 2023, 04:40 AM
914Sixer Not this is not a plug and play. This may let you... Mar 24 2023, 05:51 AM
Krieger Wow, that could make it easy. Who makes the axle a... Mar 24 2023, 08:20 AM
914Sixer Lots of axle makers on the internet. Just have to... Mar 24 2023, 09:02 AM
930cabman :popcorn: Apr 2 2023, 12:47 PM
sechszylinder Years ago, I‘ve tried the same, but was never ab... Apr 3 2023, 12:03 PM
sechszylinder any update regarding the vanagon axles ? :idea: Apr 22 2023, 01:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 04:33 AM |
