> 1976 Is it a 49 state or Cali car?
gnomefabtech
post Mar 13 2023, 06:25 PM
Car came from Nevada but I can't tell if it was originally a California car. It still has injection but doesn't have a cat or smog pump. Doesn't look like it ever had either but I'm wondering since I'm going to try and register it here in California. Thanks in advance!!
Here is the Vin:
technicalninja
post Mar 19 2023, 09:00 PM
Wow!
Wonki is Sherlock Holmes...
I can give a couple of tips on emission control: The EGR system was developed solely for the reduction of NOX via introducing an inert gas (without oxygen-could have been anything) into the intake to dampen the temperatures achieved. A small amount of exhaust gas equaled a large combustion chamber temperature decrease. If you keep the combustion chamber below 2500F oxides of nitrogen are significantly reduced.
The air pump was utilized to add additional oxygen to the cat to allow the cat to burn the HC and CO out of an extremely rich mixture. (by today's standards). Without the supplementary oxygen the cat will stop functioning earlier.
Air pump keeps cat alive; it doesn't dilute the exhaust.
Damned interesting that cat cars got an automatic replacement at 30K.
Replacing a cat every 30k would get old quickly...
What I didn't know was why Nissan added EGR valves to the Z-car in 76 and then added nothing else (49 states cars) until 1979 when everyone went to cats across the board. The 75 Z FI manifold without EGR is a rarity.
Thanks Woki!
I've found getting into tangles with city and state officials is often more trouble than it is worth.
Good luck to you if you try. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6
post Mar 23 2023, 04:38 PM
Jackstands are my life.
QUOTE(technicalninja @ Mar 19 2023, 08:00 PM) *
Not exactly. The air pump was added to trucks before cats were mandated. 1973 Chevy C10 for example. It was to finish burning the gas since carbs tended to run a bit rich.
Interesting side note. An air pump and EGR was used in the 2001 Chevy S10, but not used in the 2004 Blazer.
Thanks Woki!
EGR isn't a mandate, it's a way to reduce emissions to pass regulations that year. For example the 2001 and 2002 Nissan Maxima didn't have EGR, but the <2000 and >2003 did. The new engine (VQ35de) introduced for those years was clean enough with just ECU tuning and design. On the other hand a 2005 VW Beetle has air injection but only runs from startup to warmed up.
Dave_Darling
post Mar 24 2023, 02:40 AM
914 Idiot
QUOTE(Chris914n6 @ Mar 23 2023, 02:38 PM) *
I dated a gal who had a 68 912. Every other year, it was a huge pain to try to get it smogged because it was supposed to have a smog pump. She couldn't find one, but the official sources that CARB used said they had one in stock. (I think she found out who was supposed to have it, and they listed it in inventory but you couldn't actually order it.)
Eventually she had the car converted to a 912-6, and apparently didn't have to worry about it after that due to having different requirements.
--DD
wonkipop
post Mar 24 2023, 12:54 PM
QUOTE(Dave_Darling @ Mar 24 2023, 02:40 AM) *
--DD
68 912 is pre smog mate!
or pre serious smog. most it would have had would have been closed crankcase vent system. its even pre vapor emissions in 69.
you must mean a 76 912 E?
loaded with the same gear as 76 914 more or less.
its probably pretty farked trying to own one of those in california just like the 914.
theoretically i suppose you can find a cat for a 76?
but i bet you can't find those thermal reactor log exhaust manifolds that were on a 912E instead of a cat! ? with a bit of luck the smog inspector probably wouldn't have a clue what to look for since that bit of tech died out pretty quick. i hear the reactors used to cook the engines in BMWs. Merc liked using them too. i remember my old USA girlfriend's grandmother had a 70s merc with a reactor manifold. first time i looked in that engine bay to check the oil for her i spotted it. thought to myself what the hell is that thing.
gnomefabtech   1976 Is it a 49 state or Cali car?   Mar 13 2023, 06:25 PM
JeffBowlsby   All 75s and 76s should have a smog pump and air in...   Mar 13 2023, 06:43 PM
rgalla9146   A 1976 California car will have a EGR lamp on the ...   Mar 13 2023, 07:24 PM
Type 47   A 1976 California car will have a EGR lamp on the...   Mar 14 2023, 06:10 PM
gnomefabtech   Thanks. I'll be able to look at the car more ...   Mar 13 2023, 08:27 PM
L-Jet914   You can also check the VECI label (vehicle emissio...   Mar 13 2023, 08:29 PM
Chris914n6   Writing myself a note to look at my vin sticker fo...   Mar 14 2023, 08:34 PM
wonkipop   is that true that only california cars had cats in...   Mar 14 2023, 08:50 PM
JeffBowlsby   All 75-76 CA-model 914s required cats. https://bo...   Mar 14 2023, 09:09 PM
wonkipop   All 75-76 CA-model 914s required cats. https://b...   Mar 14 2023, 10:02 PM
JeffBowlsby   Got proof or is that speculation? We’ve heard th...   Mar 14 2023, 10:18 PM
wonkipop   Got proof or is that speculation? We’ve heard t...   Mar 15 2023, 12:29 AM
type47fan   Got proof or is that speculation? We’ve heard t...   Mar 15 2023, 12:53 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Mar 15 2023, 02:20 PM
wonkipop   righteo mr. b @[url=http://www.914world.com/bbs2/...   Mar 15 2023, 04:59 PM
JeffBowlsby   Awesome man. That is a really thorough explanatio...   Mar 15 2023, 07:27 PM
wonkipop   Awesome man. That is a really thorough explanati...   Mar 15 2023, 08:01 PM
wonkipop   Awesome man. That is a really thorough explanati...   Mar 15 2023, 08:15 PM
JeffBowlsby   There must be some other CA law here that overlaps...   Mar 15 2023, 08:58 PM
wonkipop   There must be some other CA law here that overlap...   Mar 15 2023, 09:09 PM
JORACER#40   If you live in CA DO NOT purchase a 76 914 I am go...   Mar 15 2023, 09:21 PM
wonkipop   If you live in CA DO NOT purchase a 76 914 I am g...   Mar 15 2023, 10:07 PM
gnomefabtech   Thanks for all the feedback and information! ...   Mar 15 2023, 09:27 PM
wonkipop   @JeffBowlsby and others unfortunate to own 76 in...   Mar 16 2023, 06:03 PM
gnomefabtech   If you live in CA DO NOT purchase a 76 914 I am g...   Mar 16 2023, 07:24 PM
JORACER#40   [quote name='JORACER#40' post='3065410' date='Mar...   Mar 16 2023, 08:29 PM
wonkipop   [quote name='JORACER#40' post='3065410' date='Ma...   Mar 18 2023, 06:28 PM
gnomefabtech   Well I finally got the car in my possession and it...   Mar 18 2023, 07:28 PM
wonkipop   Well I finally got the car in my possession and i...   Mar 18 2023, 07:46 PM
wonkipop   i'm not sure mr b. @JeffBowlsby has one of t...   Mar 18 2023, 07:51 PM
wonkipop   re vin stickers and manufacturer's plates. @...   Mar 18 2023, 08:07 PM
JeffBowlsby   The 76 plate omission is known but you highlighted...   Mar 18 2023, 08:57 PM
wonkipop   The 76 plate omission is known but you highlighte...   Mar 18 2023, 09:52 PM
L-Jet914   @wonkipop I see you figured out how to navigate t...   Mar 18 2023, 09:00 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 18 2023, 09:28 PM
wonkipop   i've been thinking about this problem for the ...   Mar 18 2023, 09:27 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Mar 19 2023, 02:23 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Mar 19 2023, 03:07 PM
JORACER#40   With 914 World I have access to a lot of help and ...   Mar 19 2023, 08:29 PM
Dave_Darling   A bit of recent-ish California smog history: Abou...   Mar 19 2023, 08:12 PM
wonkipop   A bit of recent-ish California smog history: Abo...   Mar 20 2023, 03:08 AM
technicalninja   Wow! Wonki is Sherlock Holmes... I can give a...   Mar 19 2023, 09:00 PM
wonkipop   Wow! Wonki is Sherlock Holmes... I can give ...   Mar 20 2023, 03:27 AM
Chris914n6   The air pump was utilized to add additional oxyge...   Mar 23 2023, 04:38 PM
Dave_Darling   The air pump was added to trucks before cats were ...   Mar 24 2023, 02:40 AM
wonkipop   The air pump was added to trucks before cats were...   Mar 24 2023, 12:54 PM
Chris914n6   68 912 is pre smog mate! Sniffer test starte...   Mar 24 2023, 01:55 PM
wonkipop   68 912 is pre smog mate! Sniffer test start...   Mar 24 2023, 05:59 PM
Dave_Darling   68 912 is pre smog mate! Nope, not at the t...   Mar 25 2023, 03:32 PM
wonkipop   68 912 is pre smog mate! Nope, not at the ...   Mar 25 2023, 04:07 PM
L-Jet914   The secondary air injection pump was added to help...   Mar 19 2023, 09:24 PM
wonkipop   The secondary air injection pump was added to hel...   Mar 20 2023, 03:20 AM
cgnj   This is my anecdotal evidence regarding non-cat MY...   Mar 20 2023, 09:36 AM
technicalninja   All car still have the function of the secondary a...   Mar 20 2023, 09:38 AM
L-Jet914   All car still have the function of the secondary ...   Mar 21 2023, 07:42 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Mar 22 2023, 05:11 PM
type47fan   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 23 2023, 12:39 PM
gnomefabtech   Good tip. Thanks   Mar 22 2023, 09:17 PM
914werke   Oh but there is more.... There is a specific airbo...   Mar 23 2023, 04:25 PM
wonkipop   Oh but there is more.... There is a specific airb...   Mar 24 2023, 02:27 AM
- Lo-Fi Version Time is now: 22nd November 2026 - 08:17 AM
